It is currently Tue Aug 04, 2026 3:42 am
Vehicle: Coil Sierra
Post Posted: Mon Aug 26, 2013 2:37 pm
On a 1l transfer im missing the four nuts that hold the flange on.
Post Posted: Mon Aug 26, 2013 2:47 pm
Use a set of Vernier calipers, or failing that a ruler for the diameter. I'd guess M10x1.25 (Same as wheel studs)
Post Posted: Mon Aug 26, 2013 2:50 pm
M8x1.25
Post Posted: Mon Aug 26, 2013 2:56 pm
since when did wheel studs shrink to M10?
those ones are M8x1.25 as monley said
Wheel studs are M12
Post Posted: Mon Aug 26, 2013 4:40 pm
Thanks heaps, yeh their kinda small for flange bolts.
Post Posted: Mon Aug 26, 2013 7:11 pm
Would the bolts for the other two front flanges be the same. It seems the wt and coily bolts are M10x1.25 and wont fit into the NT flanges
Post Posted: Mon Aug 26, 2013 7:19 pm
Yes theyll be the same. Wt are m10 and nt are m8
Vehicle: '96 LWB trayback
Post Posted: Mon Aug 26, 2013 7:21 pm
Yes,1.0/maruti both use m8x1.25 for diff/transfer flanges and transfer handbrake drum.
If it's a switched 1.0 transfer, Later flanges off a 1.3 sierra can be swapped if you need the upgraded M10 bolts and wider PCD for some reason.
Post Posted: Tue Aug 27, 2013 5:34 am
Thanks again
Post Posted: Tue Aug 27, 2013 8:00 am
Ahhh yes. Dunno what I was thinking. We can't all be right all the time :P
Post Posted: Tue Aug 27, 2013 11:12 am
Ive also noticed the coily transfer that came out had threaded flanges for the bolts to do up. The 1l one has no thead and needs a bolt and nut to join the drive shafts to the flanges.
Post Posted: Tue Aug 27, 2013 11:42 am
correct. LJs have 1litre sized bolts but flanges are all threaded
Users browsing this forum: Google [Bot] and 66 guests
