It is currently Wed Sep 30, 2026 3:28 am
Vehicle: Suzuki Grand Vitara
Post Posted: Sat Aug 24, 2013 8:54 am
Been through a bit of water lately and tones of water blasting after being up the beach... I've noticed that when I take off from a stand still or stop I can hear a tone of water sloshing around in the sills.
Question is...... Do I drill a hole, how big ? Screw size or larger with rubber bung ?
Post Posted: Sat Aug 24, 2013 8:56 am
There will be folds in the sheet metal to drain it out, I'd say they're blocked.
Post Posted: Sat Aug 24, 2013 8:58 am
They should have drain points along the seam underneath. You might just need to clear those out to get the water out
Edit: what he said ^^^^
Post Posted: Sat Aug 24, 2013 9:00 am
My Vitara did same. My water was in the front guards area.
Drain holes were blocked from wheel arch bashings.
I drilled holes, and modified my sliders, to drain mine.
Drilled holes in sliders, too, to keep them drained.
Post Posted: Sat Aug 24, 2013 2:01 pm
Thanks guys you were bang on...
I looked underneath , found the holes and thought... It doesn't look blocked to me
Got the compressor cranking and got up under there with the air gun...... Next minute I had a huge waterfall pouring out onto the ground.
Vehicle: 89 Sierra Widetrack
Post Posted: Tue Aug 27, 2013 7:35 am
Might be worth spraying something like fish oil into the sill?
Vehicle: 1995 2.0V6 Vitara LWB
Post Posted: Tue Aug 27, 2013 9:56 pm
what i do is take the nozzle of then bash it up against the sill pushing it in and then empty 1 full can each side
Users browsing this forum: Google [Bot] and 165 guests
