It is currently Thu Nov 05, 2026 8:20 pm
Post Posted: Sun Sep 01, 2013 5:37 am
Suzuki Jimny wheel bearing / spindle hub lock nut tool
Bought this from BenT "just in case". Never used
This tool is used to loosen the special wheel bearing lock nut found in the front of Suzuki Jimnys.
It is precision CNC machined and then zinc electroplated for corrosion resistance.
It features a 19mm (3/4”) hex to drive the tool using a standard 19mm or ¾” socket on a breaker bar or air impact wrench.
The wheel bearing lock nut is tightened to 220 Nm (160 lb-ft) from the factory, and is extremely tight and difficult to remove without the correct tool. It is also important that the lock nut is re-tightened to the correct torque to ensure proper bearing life. This tool fits perfectly and makes the job easy.
text stolen from BenT's ad.
Price is $45 AU + $10 AU shipping
Vehicle: 1998 Suzuki Jimny JLX
Post Posted: Thu Nov 28, 2013 10:58 pm
Hey mate, still for sale?
Users browsing this forum: No registered users and 64 guests
