It is currently Mon Aug 03, 2026 6:20 pm
Post Posted: Tue Sep 03, 2013 1:11 pm
hey all,
I currently have second hand 30x9.5 with rim of 15in sized tyres on my vitara 96. They added the height i wanted and improved the gearing for the driving i do however the handling is quite bad, which is understandable because the widest tyre im supposed to put on there is only 205mm (or just over 8in).
anyway i now need new tryes as the treads just about gone and the problem is i cant find a tyre that matches the height of 30in (762) and has width simliar to 205 or 215 or even 225 AND comes in 15in rim size.
so my question is has anyone with a similiar suzi had experience with 235/75R15's ?? in terms of how the car handles? currently the car "wobbles"??? and im assuming its because of the increased tyre width im driving on?
or anyone heard of a tyre manufacturer making 225/80R15's
thanks in advance
Post Posted: Tue Sep 03, 2013 1:40 pm
Any other modifications?
Lift can alter handling, too.
I run 30s with no problems.
Caster correction is important if it has been lifted.
Also wobbles could be any number of steering faults.
The idler arm or its bush can be a problem,
Check all normal steering parts as well
The smaller 235's will handle better, as there will be less strain on everything,
but I think its a steering/suspension problem.
Vehicle: SWB Sierra
Post Posted: Tue Sep 03, 2013 1:53 pm
X2
Its not the tyres causing the problem, they will only be exacerbating existing faults.
Fix your car and 30's will be fine.
Post Posted: Tue Sep 03, 2013 1:55 pm
i'm guessing wheel balance or out of round tyres would be the cause of the wobbles in a vitara.
where the 30's you got 2nd hand?
Vehicle: SWB Sierra
Post Posted: Tue Sep 03, 2013 2:06 pm
In my experience out of round tyres don't really produce wobbles.
But poorly balanced or buckled wheels would.
Post Posted: Tue Sep 03, 2013 3:47 pm
Mine wobbled a bit before replacing idler arm/bush.
I'd also look at adjusting up the steering box.
Vehicle: SJ80, SE416
Post Posted: Tue Sep 03, 2013 4:40 pm
X2, mine had a very annoying wobble at high speed until I replaced the idler arm. New greasable one was about $50, and took about 20 minutes to replace.
If I jacked up the passenger side wheel and tried to steer it by hand it I could see the idler arm moving up/down about 1"!
I still have a very slight wobble at the moment however, so I'm replacing all the tierod ends shortly to remove the rest of the play in the front end.
Post Posted: Tue Sep 03, 2013 8:30 pm
How is caster affected by lift in a Vitara?
Post Posted: Tue Sep 03, 2013 9:46 pm
:oops: meant camber, stoopid keyboard.
Though caster/castor correction was very nice after my lift.
Post Posted: Fri Sep 06, 2013 10:45 pm
yes the tyres were second hand, and came off wider rims so when they first went on the handling was outrangeous until they wore in.
The car has no other modifications but has had some use..There wasnt any play in like the steering but on the road it felt like it would track either way and gripp and i'd have to wobble to keep it on track ahah Ive since ordered pirellis 215/80r15 from over east but il have a look into idler arms and steering box as it sounds like thats the true problem
thanks for the advice guys, appreciate it
Users browsing this forum: No registered users and 17 guests
