It is currently Mon Aug 03, 2026 4:24 pm
Vehicle: Sierra
Post Posted: Tue Sep 03, 2013 8:03 pm
Trying to remove my rear drums and one of the splines is stripped and the stud just keeps spinning.
Any ideas on how to undo it?
Vehicle: sj51
Post Posted: Tue Sep 03, 2013 8:07 pm
cold chisel is one option
Vehicle: LWB Sierra & XL7
Post Posted: Tue Sep 03, 2013 8:29 pm
Hit with a hammer to remove the stud, and replace it
'92 Vitara & Camper trailer
Vehicle: sj51
Post Posted: Tue Sep 03, 2013 8:31 pm
think he means the nut is still on the stud
Post Posted: Tue Sep 03, 2013 8:42 pm
I'd just cut the nut off and replace the stud. If the hole in the axles is stuffed from the stud spinning i'd just source a 2nd hand axle.
Post Posted: Wed Sep 04, 2013 6:59 am
Well that's a bit more of a complex operation then.
Angle grinder to chop it off.... Then hammer ;)
Post Posted: Wed Sep 04, 2013 7:15 pm
More complex that what?
bye
Post Posted: Wed Sep 04, 2013 7:24 pm
Hi
:? what bit don't you get?
pretty sure he means it's not as simple as knocking out the old stud as mentioned in an earlier post of his & if the nut is still on & it's spinning the knurled section on the stud or the wheel nut is stripped it will need to be cut off.
Bye
Post Posted: Thu Sep 05, 2013 12:54 am
An explanation of an explanation, now that's deep.
Thanks Atari , your like a miniature Buddha ;)
Users browsing this forum: No registered users and 24 guests
