It is currently Mon Sep 21, 2026 4:02 am
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
Post Posted: Sun Sep 01, 2013 9:53 pm
possibly a worn Hub, thats why i had to re do mine. maybe pull the locking ring off a try tighten them up a little bit more? or pull the hub off and get someone to press the bearing anymore into place?
assuming you used decent bearings?
Vehicle: sj70 sierra
Post Posted: Sun Sep 01, 2013 11:14 pm
Thanks for the reply. I tried tightening the cap some more but couldn't get it the next screw hole. What gets worn out in a hub? It feels to me like the bearing has the play in it rather that the hub having a problem. Took it to an engineering shop the first time to press it in so I would assume they put it in far enough,might take it back to them though. I used a bearing from eBay that cost $50 what is your definition of decent, I would have thought anything would last longer than a week
Post Posted: Mon Sep 02, 2013 7:45 pm
well all I know is that the same thing happened with mine, put a new hub on and its great. the bearing was really easy to press into the old hub. Sorry i thought you mean you put the bearing in with a hammer and punch.
anything that has a bit of reputation and background i guess, i bought mine of "weaves" an AZ member (the bearing man, works at a bearing shop) so i know its a decent bearing. but anything that is Chinese is going to be a lower std of bearing.
are you sure its the bearing thats got the play? not something that hasnt been tightened up correctly (lower strut mount ect)
Vehicle: 96 vit hardtop
Post Posted: Mon Sep 16, 2013 10:50 am
For bearings, go to Allied bearings
http://www.alliedbearings.com.au/datasheets/suzuki
Front Bearing kit for a vit are $56.00 -- Everything you need.
Pretty cheap, and good quality.
I'm doing my bearings this week, as there's a grinding in the front left....Am using a small press from supercheap...
Vehicle: 99 Grand Vitara
Post Posted: Tue Sep 17, 2013 2:14 am
Are those ones a single bearing? Whats better tapered or those? I just did my driver side and got tapered ones and cost $85 for the kit :(
http://www.strictly4x4.com.au
Post Posted: Tue Sep 17, 2013 12:04 pm
they are a single outer bearing with two inner rollers. non tapered
Post Posted: Mon Sep 23, 2013 10:11 am
Just an update for anyone struggling.
I did my bearings on the weekend. Used a 6Tonne press, but I couldn't get the inner race out.
Took it to the shop and they had a 20T press.
One race came out with some force the other wouldn't come out with the 20T press. So we had to heat it up with an oxy, then it snapped out much easier.
The new race went in quite easily after that , but just a word of warning, that sometimes a 6T press isn't strong enough....
Cheers.
Vehicle: LWB Vitara
Post Posted: Sat Aug 30, 2014 1:34 pm
I know this is an old thread but I thought I might update it for people who still don't know.
The wheel bearings are a Cassette double taper type wheel bearing (new ones may be just ball bearing type) so they need to be done up tight.
That'll be the reason why they didn't last longer then a week.
You'll need the wheel bearing nut tool and will need to torque it up to 170 - 250 N-m or 123 - 180 ft-lb
No further adjustment is required and they should have no play in them.
Post Posted: Sat Aug 30, 2014 2:14 pm
Thanks for the update mate, handy to know
Users browsing this forum: No registered users and 163 guests
