It is currently Mon Aug 03, 2026 6:01 pm
Vehicle: Suzuki jb43 jimny
Post Posted: Thu Sep 26, 2013 6:20 pm
Howdy az crew, I'm considering removing my front away bar in my 1994 swb Tara. And just woundering if anyone has done it and if its in proved the front flex off road. Thanks in advance
Post Posted: Thu Sep 26, 2013 6:21 pm
yess!!
Post Posted: Thu Sep 26, 2013 6:23 pm
:rofl: Haha is that all you have to say mate
Post Posted: Thu Sep 26, 2013 6:31 pm
He's a man of many words!
Post Posted: Thu Sep 26, 2013 6:54 pm
yess!!
Tried with and without, long term off and on road.
For my set up I was happier without it.
Post Posted: Thu Sep 26, 2013 11:31 pm
Did u notice it worked better off road
Post Posted: Fri Sep 27, 2013 6:53 am
Atari gave you your answer.
Yes.
Post Posted: Fri Sep 27, 2013 7:28 am
Not only did mine work better off road, it felt safer and more stable.
With sway bar fitted, it would lift a front wheel more often, then suddenly lurch as weight transferred, very unsettling.
Vehicle: Black '96 X-90
Post Posted: Fri Sep 27, 2013 4:01 pm
Same as above. I've disconnected mine.
It's a little soggier on road. But I don't really go around corners fast enough to worry about that.
Post Posted: Sat Sep 28, 2013 8:14 am
Haha thanks for all your answers no one ran into issues with cvs for any reason, I.e the sway bar no longer limiting the droop a much.
Post Posted: Sat Sep 28, 2013 8:29 am
I found the sway bar only limited my up travel, it still drooped full droop.
The up travel don't stress cv much, angle is still mild.
So no difference to cv stresses on mine.
Do what I did, run with and without, get out and look n measure stuff, see what is right and safest for you.
Post Posted: Sat Sep 28, 2013 11:41 am
Alright looks like I'm finding a rock haha then ill remove it and do the same again
Vehicle: 95 Vitara Hardtop
Post Posted: Sun Sep 29, 2013 8:01 am
As above replies, my SWB is much better off road, and still OK on the road (with Dobinson lift kit).
Post Posted: Mon Sep 30, 2013 6:50 am
Sway bars gone :) can't belive the difference
Users browsing this forum: Google [Bot] and 11 guests
