It is currently Wed Oct 28, 2026 2:01 pm
Post Posted: Sun Jun 28, 2009 10:57 pm
Well with the front bar and winch install done and dusted, sliders were the next on the list of things to do.
Started with a straight bar and brackets.
Front mount
Rear Mount.
Sill bar in place.
Wing welded in place.
Bolted in place.
Just have to make a middle support bracket and the drivers side. Paint it up and I'll be ready to attack the rear bar.
Don't know whether to grind off the sill brackets or put the original side plastic sills back on. LTM wants them off.
Post Posted: Mon Jun 29, 2009 4:45 am
It's a bit iffy on the I touch, but is that rear mount to the body as well as the chassis??
Post Posted: Mon Jun 29, 2009 1:18 pm
Mounted to the chasis only.
SS
Post Posted: Tue Aug 04, 2009 10:57 pm
Care to make me some? "$" ?
85 Holden Drover Soft top stocko.
[quote="losfer"
Post Posted: Fri Aug 07, 2009 11:43 pm
Nup, sorry fourby did it to save some dollars. The hours put in would make it way too expensive. It was a mission ,as I don't even have a proper bench or vice to work with. :cry: Ever tried notching tube with a hand drill. :twisted:
Man I neeed a shed with cool stuff in it.
Post Posted: Fri Aug 07, 2009 11:50 pm
Forgot the finished product.
Post Posted: Sat Aug 08, 2009 12:06 pm
They look good mate! Glad to see you took the 'rustcatchers' off!! :lol:
Post Posted: Sat Aug 08, 2009 4:49 pm
Slow down on the mods Dave, there won't be anything left for LTM to do !
Sliders look good.
Post Posted: Sun Aug 09, 2009 12:07 am
Sliders look good.
Don't worry still plenty to do. :D
LTM does the the design work.
Vehicle: 75 Cruiser
Post Posted: Sun Aug 09, 2009 1:06 am
340 views, 8 replies, and no one's mentioned the spelling of "siders" in the topic... sorry, can't help it :lol:
Vehicle: WR250F/Jeep XJ
Post Posted: Sun Aug 09, 2009 1:40 am
loved that little piece of gold you left in the how do i fit 32s thread Steve. lol.
Fantastic effort on those sliders DMAC. They look very solid.
Here's my take on sliders for sierras...
Ok i'm only gonna say it once. i don't understand why people go down this track when making sliders, you have now effectively reduced your guard clearance by at least 2 inchs. Which means things you never used to get hung up on will now be scraping everywhere....lucky you have sliders everyone might say!!!!
http://www.off-road.com/trucks4x4/artic ... ?id=277648 - This is a way to build sliders, but if I was going to do it I would bolt them straight to the body sills and plate the inners to spread the load. a loss of only 20mm maximum and nothing hanging below to get hung up on. When i get around to building mine i'll post a thread about it.
Post Posted: Sun Aug 09, 2009 1:46 am
50mm body lift and 40mm OD pipe slider rail... Where is the lost clearance????
Spelling... bah humbug... this isn't Outers
Vehicle: 75 Cruiser
Post Posted: Sun Aug 09, 2009 2:12 am
I think you'd be losing 4 or 5 inches of clearance having tube/pipe sliders?
If you chop out your sills and do angled box sills you wll gain an inch, so that's a fair bit of clearence (6 inches?) over someone wih normal tube sliders. A definate advantage :)
Vehicle: Nissan
Post Posted: Sun Aug 09, 2009 2:28 am
thats what im doing 8)
Pearce-toff Racing
Post Posted: Sun Aug 09, 2009 4:38 pm
Whew that was an easy fix I added an "l". Wish all my mistakes were that easy to fix.
As for losing 50mm less clearance and getting hung up more than anything else.
My take is the chasis and suspension brackets all sit lower and I hit them more. Just wanted to protect the sills without hacking into the panel work. I did like the functionality of the square sliders Dank, but I'm a round type of a guy. 8)
LTM21 needs the little step to help get in too. :rofl:
Post Posted: Sun Aug 09, 2009 11:08 pm
I'll let you off DMAC because you have a very cool front bar :wink:
A side step does come in handy as well. Good work....
Post Posted: Mon Aug 10, 2009 12:46 am
No worries Dank. I kinda wished I had seen the right angle style before I started. It is in the design bank now.
1. It doesn't interfer with the panels.
2. Simpler
3. Could quite easily put a wing on it too without notching.
I'm sure it won't be the last set of sliders I make. The Zuk bug bites hard.
