It is currently Thu Oct 22, 2026 4:35 am
Vehicle: Suzuki Sierra 1996 Coily
Post Posted: Sat Oct 12, 2013 10:10 pm
I am having issues with my sierra, every time I try to accelerate weather it is from stand still or while already moving my revs drop hugly (if I want to get going I have to be atleast at 4000 revs or it will stall)
Anyone know what it might be??
Post Posted: Sun Oct 13, 2013 7:20 am
Once underway how does it respond to the throttle.
How long since you done a service, ie looked at rotor cap leads and plugs, replaced.
Vehicle: 98 Coily
Post Posted: Sun Oct 13, 2013 6:52 pm
I had similar sounding issue awhile back... cleaned out the fuel lines and replaced the fuel filter and no problems since.
Post Posted: Mon Oct 14, 2013 8:55 am
Replied to you in this thread:
viewtopic.php?f=5&t=43312
Post Posted: Mon Oct 14, 2013 5:55 pm
ok so I get to the car to replace the fuel filter.......... Where is the fuel filter on the car???
Vehicle: SJ80, SE416
Post Posted: Mon Oct 14, 2013 6:08 pm
Follow the fuel lines on inner side of the drivers side chassis rail to the rear wheel arch where you should see a filter bolted onto a bracket on the rail.
Post Posted: Tue Oct 15, 2013 11:38 am
Yeh I found it and the new fuel filter didn't fix it. I have a carburettor repair kit is there anything that I need to look out for when pull apart or and put I back together????
Post Posted: Tue Oct 15, 2013 11:45 am
doesnt sound like carby to me, sounds like the electrics, have you checked them.
Cap, rotor, leads and plugs ?
Post Posted: Tue Oct 15, 2013 12:39 pm
They are all in good condition and working
Post Posted: Tue Oct 15, 2013 4:05 pm
So aside from that does it drive just fine? What are the other symptoms?
Post Posted: Tue Oct 15, 2013 6:04 pm
unsure about sj80 but earlier sierra had a clutch pedal switch for emission control , if the switch played up displayed similar symptoms to yours , you disconnect the wires to the switch and jump them with a jumper wire and it fixed it.. worth a shot anyway if the sj80 does indeed have this switch.
Vehicle: Coil Sierra
Post Posted: Tue Oct 15, 2013 9:00 pm
Is it just revving low rpms or backfiring and shaking?
Post Posted: Thu Oct 17, 2013 12:31 am
Thanx guys for all the help it turns out that it was the fuel filter I just had to run it a little longer it has completely fixed now :-)
Just fitted some new tyres, I now have all terrains instead of almost bald road tyres
Post Posted: Thu Oct 17, 2013 1:04 am
See you this weekend! Armsup
Users browsing this forum: Google [Bot] and 179 guests
