| Author |
Message |
Marko_SJ
Joined: Tue Jan 17, 2012 1:40 am Posts: 2979 Location: Darwin, NT
Vehicle: WT sierra, GU CRD
 Posted: Mon Oct 14, 2013 4:58 pm |
zukenutter wrote: I had a few heavy loads behind my Sierra including a similar sized tinny. I did a trip to Fraser with somewhere in the range of 400kg behind it and four people on board, like you say... common sense required.
Anybody tow a couple of jet skis behind a Sierra? I don't think I would. Maybe-maybe if it was braked. The boat ramp could pose problems with traction, jetskis being heavy and a sierra being light.
_________________ I love ZD30. :)
zukenutter
Joined: Sun Feb 08, 2009 10:30 pm Posts: 9045 Location: Brisneyland
 Posted: Mon Oct 14, 2013 5:08 pm |
The_Amateur wrote: The boat ramp could pose problems with traction, jetskis being heavy and a sierra being light. True that
_________________ Click WWW below for STICKERS
Dingo
Vehicle: 2013 standard jimny
 Posted: Mon Oct 14, 2013 5:57 pm |
G'day, I tow my 4.4 metre tinny on trips up to 350 km each way and have no dramas, admit that I cruise on 110 and not 130 but it does well. The fuel use does increase but it is still better than anything else I have owned even with that increase. Like every trip it is your call on how safe you drive. Have a good evening.
N.T.
Vehicle: Suzuki Sierra Stockman
 Posted: Tue Oct 15, 2013 1:36 pm |
Dingo wrote: G'day, I tow my 4.4 metre tinny on trips up to 350 km each way and have no dramas, admit that I cruise on 110 and not 130 but it does well. The fuel use does increase but it is still better than anything else I have owned even with that increase. Like every trip it is your call on how safe you drive. Have a good evening. You cruise on 110 kpm in a sierra towing a 4.4 mtr tinny for trips up to 350k so I can assume you also have a fair bit of gear as well??? You running a commy V6 transplant???
Moph
Joined: Sat May 19, 2007 11:30 pm Posts: 2535 Location: Perth
Vehicle: 93 Sierra
 Posted: Tue Oct 15, 2013 1:57 pm |
N.T. wrote: You cruise on 110 kpm in a sierra towing a 4.4 mtr tinny for trips up to 350k so I can assume you also have a fair bit of gear as well??? You running a commy V6 transplant??? Not sure about the weight of his tinny, but I have towed my camping trailer (around 450kg loaded) across the Nullabor and up to the top end of WA using a stock G13BA. Sat on 100-110kph in 5th most of the way depending on headwinds, and got it up to 125kph in 4th overtaking roadtrains. That was with 2 people, 2 dogs and a fully loaded Zook. While the trailer actually tows very nicely and in some ways seems to tame the roadholding of my Zook, I wouldn't be advising towing anything heavier or more subject to wind sway. Sierras just are not heavy enough to put anything big behind them sensibly, hence their 450kg towing limit.
Pooke
Joined: Sun Nov 18, 2012 12:03 pm Posts: 66 Location: New Zealand
Vehicle: 95 SJ70, 96 Escudo v6
 Posted: Tue Oct 15, 2013 2:26 pm |
I cant find the tow rating anywhere for my NZ registered Samurai. But I have towed a few different loads with it on my 8x4 trailer, e.g Moving house oh and a trailer of dirt, without any drama's apart from being a bit slow. Stopping isnt much of a worry but then theres not enough road to get it up past 80kph when towing. Also the longest distance I would have covered would be 50km.
Once towed a Mitzi lancer on a dolly with a Ford Laser, now that was interesting/dodgy !!!!!!!!!!
Marko_SJ
 Posted: Tue Oct 15, 2013 2:31 pm |
Pooke wrote: I cant find the tow rating anywhere for my NZ registered Samurai. But I have towed a few different loads with it on my 8x4 trailer, e.g Moving house oh and a trailer of dirt, without any drama's apart from being a bit slow. Stopping isnt much of a worry but then theres not enough road to get it up past 80kph when towing. Also the longest distance I would have covered would be 50km.
Once towed a Mitzi lancer on a dolly with a Ford Laser, now that was interesting/dodgy !!!!!!!!!! How many kays? Mophs engine has been rebuilt so it is not tired N.T. wrote: Dingo wrote: G'day, I tow my 4.4 metre tinny on trips up to 350 km each way and have no dramas, admit that I cruise on 110 and not 130 but it does well. The fuel use does increase but it is still better than anything else I have owned even with that increase. Like every trip it is your call on how safe you drive. Have a good evening. You cruise on 110 kpm in a sierra towing a 4.4 mtr tinny for trips up to 350k so I can assume you also have a fair bit of gear as well??? You running a commy V6 transplant??? Jimny m13a stock gearing and tyres would do it.
Pooke
 Posted: Tue Oct 15, 2013 2:36 pm |
Quote: How many kays? Mophs engine has been rebuilt so it is not tired 115000kms from new and definatly not tired. But have you seen the roads here in Northland NZ? Any part thats flat or straight for more than 2 km is rare!
Marko_SJ
 Posted: Tue Oct 15, 2013 2:39 pm |
Pooke wrote: Quote: How many kays? Mophs engine has been rebuilt so it is not tired 115000kms from new and definatly not tired. But have you seen the roads here in Northland NZ? Any part thats flat or straight for more than 2 km is rare! Negative to having seen NZ roads. Some of ours are flat as a tack though, get what you mean there.
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Tue Oct 15, 2013 3:19 pm |
Trailer is aprox 1200kg with override disc brakes and it towed fine at 80kph. I now tow the same boat with my jimny
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
