It is currently Sat Oct 24, 2026 8:53 am
Vehicle: 1985 lwb sierra UTE
Post Posted: Wed Oct 16, 2013 6:38 pm
Wich cable do u use for the balino conversion ??
Post Posted: Wed Oct 16, 2013 6:51 pm
For a BalEno you could use Vitara, Swift, Corolla, Hyundai or custom.
Post Posted: Wed Oct 16, 2013 6:52 pm
I tried the balino one but it was way to long.if a vitara one works ill buy one tomorrow
Post Posted: Wed Oct 16, 2013 7:10 pm
the problem with the cable that fits the baleno throttle body is that it wont fit the sierra pedal without either a modified cable , a dodgy mod at the pedal or a modified pedal . i usually modify the pedal myself to suit the cable. think i used a maruti alto cable on the last conversion and modified the pedal to suit.
Vehicle: Cobra 427
Post Posted: Wed Oct 16, 2013 7:50 pm
my mat did this http://www.prozook4x4.com/forum/viewtopic.php?f=14&t=27
Post Posted: Wed Oct 16, 2013 7:55 pm
Jameszook wrote:
Could u post a pic or explain ..u need to be a registered user for that to work
Post Posted: Wed Oct 16, 2013 7:57 pm
prosook4x4arepoopunchinghomos wrote:
When fitting a G16B into a Sierra both the Sierra throttle cable and the Baleno Cables are the wrong length.
The Baleno cable can easily be modded to fit.
The end that attaches to the engine is the correct fitting so leave this.
-Cut the pedal end off
-Carefully measure and shorten the outer housing to the right length
-Remove pedal and grind off the tag that the cable end hooks into
-Enlarge the hole to allow a bicycle brake anchor bolt to fit
-Re attach pedal and adjust
Post Posted: Wed Oct 16, 2013 8:02 pm
:peaceout: U guys rock
Users browsing this forum: Google [Bot] and 115 guests
