It is currently Fri Nov 13, 2026 12:35 pm
Post Posted: Mon Oct 21, 2013 8:07 pm
Hey guys I'm chasing a mk 2 or 3 dizzy for a swift gti head. Ipswich Brisbane area. Changing from mk1 angle adapter for aftermarket management. Pm or reply here.
Cheers chris
Post Posted: Mon Oct 21, 2013 9:32 pm
i have built a few angle drives but dont have the pieces around to build anymore. if u get the bits i will build you one mate.
Post Posted: Tue Oct 22, 2013 10:35 am
You built a angle drive kit for a MK2/MK3 dizzy?
Post Posted: Tue Oct 22, 2013 1:53 pm
No it's mk1 now I'm changing to mk2 or 3 and want to get rid of the angle drive. Sorry.
Post Posted: Tue Oct 22, 2013 2:35 pm
What aftermarket management? Will it be compatible with the odd trigger wheel spacings of the mk2/3's?
Post Posted: Tue Oct 22, 2013 2:40 pm
sorry i didn't read it right!
Jr is on to it tho, you might be better off with a g16b dizzy (this is the exact reason a g16b dizzy wont work with a mk2/3 gti and angle drive)
Post Posted: Tue Oct 22, 2013 4:28 pm
Could just stick to the Mk1 and gut the dizzy so it just acts as the cam sensor. Very similar setup as the early VR type G16B dizzy.
Post Posted: Tue Oct 22, 2013 4:29 pm
at a guess id say it would be running a sierra dizzy...
Post Posted: Wed Oct 23, 2013 9:12 am
I'll probably end up with a haltech sprint 500. So would I just be able to run my current one as a sensor for the computer or will I need to change it?
Post Posted: Wed Oct 23, 2013 9:13 am
So a g16b dizzy will go straight in?
Post Posted: Wed Oct 23, 2013 9:24 am
Yes as long as the ECU accepts variable reluctance sensor input. All you have to do with your dizzy is lock out all advance mechanisms and unsolder/remove the ignition coil driver inside of it.
Post Posted: Wed Oct 23, 2013 7:30 pm
Righto thanks. I'll look into it further.
