It is currently Tue Nov 03, 2026 12:49 am
Post Posted: Fri Oct 25, 2013 8:31 pm
Just had the g16b put in the my coily and whilst testing it out on day 1 i have cracked my transfer case (very big) across the input shaft housing area. (To dark to take photos)
Coily with wt transfer with 4:9:1 gears.
Has any body had/heard of this happening? Also i havnt pulled it out yet but do you think the gears would have survived?
Cheers in advance.
Post Posted: Fri Oct 25, 2013 9:15 pm
I think the gears caused it. But that's just my opinion as I've seen this before on friends cars.
Post Posted: Fri Oct 25, 2013 9:59 pm
Cheers kenn, have the gears normally survived?
Post Posted: Fri Oct 25, 2013 10:10 pm
Long enough to make it to the bin. The ones I've seen did a bit more than just crack the case so yours might be ok plus they were older versions, I think the new ones are made a bit better now. I still wouldn't run them unless someone wanted me to do a destruction test on them.
Post Posted: Sat Oct 26, 2013 12:47 am
i assume you fitted the WT Tcase without bracing the mounts? (Search Roctoy Ring on here)
Post Posted: Sat Oct 26, 2013 7:33 am
It was the old rockhopper gears that use to shit them self all the time
Users browsing this forum: Google [Bot] and 96 guests
