It is currently Thu Nov 05, 2026 9:27 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
Vehicle: 92 WT Sierra
Post Posted: Sat Nov 02, 2013 4:29 pm
Top
Hi Everyone time has come to sell my Vitara to make way for a sierra 8O
So far it has the following:
approx 60mm spings lift (have sagged a bit)
40mm body lift
5x 235/75/15 all terrains and 4 30x9.5x15 maxxis mud terrains
80ch uhf
TwinStickOffroad tank guard
Diff breathers
tigerz11 6000lb winch with synthetic rope
a few interior mods led light, 12volt power etc.
rock sliders
bash plate (looking worse for ware)
The bad:
I cracked the front diff housing and broke one tooth of the crown gear, I have a replacement alloy housing but haven't had the time to source a new crown gear.
One small dent on the passenger quarter panel near the headlight, still have no idea how it got there.
Usual scratches from trees etc.
One headlight trim missing but being delivered on Monday
It has just over 160 000KM's on the clock and the rear main seal and clutch have been replaced with a genuine seal and exceedy clutch kit less than 200km ago.
I also have a tow bar that I have started to mod to suit the tank guard, set of shock spacers cut out and just need welding, all original suspension.
The 2nd back seat is in the garage and just needs to be bolted back in (takes less than 5 minutes)
I can sort out the diff but will probably go to 5.12's as they are readily available, if not the old one is usable but I wouldn't run it.
Asking $7000 or a bit less with the diff still out, but open to reasonable offers or swap for a sierra oc similar value
Located near Hornsby, Sydney
sorry if the pics are too big
You can contact me via pm, or email n.demasi@yahoo.com I'm normally at uni and have no reception but am on a computer most of the day.
Post Posted: Sun Nov 03, 2013 4:51 pm
Top
Sorry no longer for sale :) bit of a stuff around but have sorted out something
Users browsing this forum: Google Adsense [Bot] and 12 guests
