It is currently Thu Oct 01, 2026 10:02 am
Vehicle: Samurai G16, DMax.
Post Posted: Sun Dec 08, 2013 2:31 pm
I've just bought a '99 Jimny with 70 K on the clock. I'll be doing a cam belt shortly but can anyone tell me if this is an interference motor or will it die quietly if the belt goes?
Post Posted: Sun Dec 08, 2013 3:00 pm
It is not an interference motor. As far as I know all G series motors are free spinners.
Post Posted: Sun Dec 08, 2013 3:33 pm
Thanks Steve. I've had a few "A"s but this is the first computer controlled 1300 I've had to deal with. Steve.
Post Posted: Sun Dec 08, 2013 11:44 pm
The SOHC 8v is non-interference, the DOHC 16v IS an interference motor, and I would not take the chance with the SOHC 16v.
Vehicle: '96 LWB trayback
Post Posted: Mon Dec 09, 2013 2:58 am
Which factory original Suzuki DOHC 16v are you referring to?
If you build a hybrid G16/G13b and end up with an interference design (which you do), that's your own damn fault.
Anyone building hybrid engines should have the know-how to keep themselves out of trouble with something this simple.
G16a SOHC - definitely non interference, like all factory G series engines.
Post Posted: Mon Dec 09, 2013 5:36 am
The G13BB is a non-interference engine.
Post Posted: Mon Dec 09, 2013 6:58 am
Thanks guys. My Jimny is an unmodded G13BB. Nice and simple. Unfortunately it was abandoned by the PO (American actor who failed to make it on Lord of the Rings/Hobbit). I'm now getting it re-complianced and the last thing I want is for the cam belt to snap and cause mechanical problems. Over here our compliancing regulations means it has to appear like a new vehicle. What a nightmare task! I'm nearly there but our pedantic inspectors, at the only place that is approved to do this, keep finding more small things to correct. Today's fault is "rear brake imbalance" even though 9 days ago they tested the brakes and they were spot on!
Post Posted: Mon Dec 09, 2013 11:31 am
May I safely assume that since you mention a hybrid G16/G13b that you're aware that Suzuki built a 1.3 DOHC 16v engine commonly known as the G13b, and fitted to the 89~94 SF413 Swift GT/GTi ? Hopefully that meets your definition of "factory original".
May I also take this opportunity to point out that the topic of this thread is the G13BB SOHC 16v engine and not the G16a SOHC?
Vehicle: 85 ' Drover
Post Posted: Mon Dec 09, 2013 12:07 pm
I think its best to treat all engines as interference engines.
Even when working on engines that you know arent interference you just dont want to take the risk of bending a valve. Once you take that belt off, don't move a thing. This way you can't be caught out.
Post Posted: Mon Dec 09, 2013 1:36 pm
I think that's good advice, but the specific issue is "is the engine going to break if the timing belt breaks" and for all sohc g motors the answer is no.
Post Posted: Mon Dec 09, 2013 1:39 pm
Fordem: Right you are mate, sorry. Was a late night at work and for some reason I read your "DOHC 16v" as "DOHC 1.6litre", my bad.
Post Posted: Mon Dec 09, 2013 2:44 pm
What about if the head has been shaved? I always worry that with such engines that over the years the head has been shaved enough times to make it interference. Especially if you dont actually know the history. Probably not worth worrying about though.
Post Posted: Mon Dec 09, 2013 4:24 pm
If the head has been shaved enough to make it an interference motor , it was an apparently otherwise stock G13BB running stock management it would already be broken.
Users browsing this forum: No registered users and 31 guests
