It is currently Wed Sep 02, 2026 12:35 am
Vehicle: 2001 Suzuki Grand Vitara
Post Posted: Sat Nov 23, 2013 5:39 pm
Hey Peoples,
Does anyone know a place in Australia where I can purchase collapsible spacers for front and rear diff's for a 2001 Suzuki Grand Vitara? I've only managed to find one place online, and they were after something like $37 for one. Do you think its possible to get it cheaper?
Something in the USA maybe?
Perhaps an interchangeable spacer with another model like Samurai etc that might be bought cheaper?
Thanks
Kind regards,
Chris
Post Posted: Mon Nov 25, 2013 8:27 am
thats a fair price id say. have your tried suzuki?
Vehicle: 85 ' Drover
Post Posted: Mon Nov 25, 2013 11:39 am
A differential shop would propably have them on the shelf.
Post Posted: Mon Nov 25, 2013 9:36 pm
I've not gone to a dealer yet because I suspected I might be charged an extraordinary amount of cash for what is essentially a cheap item, as per past experience. But this morning I decided I've got to at least have the dollar amount. So I will try them tomorrow if possible.
I hadn't even thought of a diff specialist, that makes sense to at least try them. But I guess I didn't consider it because I would've thought they'd be just that, a specialist and so I doubt they'd keep stock, but rather it would be an item they'd just order direct from the dealer themselves at a specific time of needing it and just on-charge the customer.
Ive gone down the route of shims (to use with the old spacer) but cant find anything that's truly appropriate in size to sit against either the inner or outer pinion bearing.
I thought there would EASILY be a company making universal ones out there somewhere, to fit ranges of vehicles (or rather ranges of diffs?) but that seems to be a no.
Post Posted: Tue Nov 26, 2013 2:41 am
http://pages.ebay.com/link/?nav=item.vi ... 1218274589
Your welcome.
Post Posted: Tue Nov 26, 2013 11:47 am
Just got off the phone to Suzuki. Mine is an 01 LWB GV with a J20a engine.
Part number 27315-78E00 costs me $26.14 plus gst. To suit rear and Suzuki has 6 in stock
Part number 27315-60A01 costs me $26.14 plus gst. To suit front and Suzuki has 1 in stock.
Dave
Vehicle: Suzuki Sierra
Post Posted: Tue Nov 26, 2013 3:18 pm
Genuine parts rock
Vehicle: SJ80, SE416
Post Posted: Tue Nov 26, 2013 3:41 pm
sierrajim wrote:
Genuine parts rock
And are often well priced also...
Post Posted: Tue Nov 26, 2013 9:24 pm
mrw82 wrote:
http://pages.ebay.com/link/?nav=item.view&id=261218274589
Your welcome.
Sorry mate, unless you know it to be compatible I couldn't go for it, as my model isnt listed. I got a GV SQ625. I appreciate you doing a hunt though
Post Posted: Tue Nov 26, 2013 9:29 pm
Dave
Hey bohuler,
Could you give me the phone number or name of the Suzuki place you called up please. I will certainly order at that price. Its by far the best ive seen.
I got a quote for them today too, and Suzuki in Mellville, WA is after $40 each, and $20 for freight.
Post Posted: Wed Nov 27, 2013 6:37 am
I would think that the part number would be the same for the SQ625 but mine is a SQ420 .
That was trade price so $40 is probably pretty close to correct rrp inc gst. If you want to PM your vin number I can ring and order them then get the put in a postbag and sent up to you :D
Or give FTG Holden Parts a ring on (03)9753-1277. Just make sure you have your vin number ready cause they need to order bits from a vin.
Dave
Post Posted: Thu Nov 28, 2013 8:46 pm
Hey bohuler,
Thanks for the information, I ended up calling them and giving them my VIN. Im seriously impressed with them, the total price ended up being $52.78 (or something very close!), so thats less than $27 each. Peter, a bloke there commented that you had called them and unfortunately they are different part numbers for the SQ625. I will post the part numbers as a reference when I get them (if they're written on the packets).
I also didnt realize we could call a different car company to get those parts... doubly impressed!
Thanks everyone
Post Posted: Thu Dec 12, 2013 7:14 pm
Hey guys, just a final reply if anyone wanted to know the genuine part numbers for collapsible spacers for front and rear diffs
These are parts for a 2001 Suzuki Grand Vitara SQ625 2.5ltr V6
27315-60A01 appears to be for the front diff
27315-78E50 appears to be for the rear diff
Post Posted: Thu Dec 12, 2013 7:48 pm
BTW Ive heard various tricks/ways of not having to go through the pain of buying new spacers, for example using hardened steel shims with the old spacer, or heating the old spacer up and giving it a nice hit where it bellows out with a mallet to increase its size again, or similar other concepts. Apparently the shim trick is used often when he installs lockers in client 4x4's and hasnt had a problem so far. I did see a coment somewhere else this shouldnt be done in racing applications, but given we are speaking of suzukis here, i doubt that would be an issue.
So based on this, I thought I would provide the length of each new spacer if someone else finds it handy for using shims or another method of reusing their original spacers;
The new Rear spacer is exactly 51.72mm long
The new Front spacer is exactly 56.68mm long
Just remember if you intend to try the shim idea you MUST put the shim on either side of the original collapsible spacer, you CANNOT put the shim between the inner pinion bearing and pinion gear itself (this would result in your pinion and crown gear not meshing at the factory setting), and obviously dont put in on the large side of the outer pinion bearing either. Essentially, you can put it anywhere between the two pinion bearings is acceptable from what I understand.
Post Posted: Fri Dec 13, 2013 4:22 am
Its easier to just put a new spacer in :lol:
Only time you should have to fuck around with shims is if you use a solid spacer.
Post Posted: Fri Dec 13, 2013 8:23 am
With exception for the language ;) I tend to agree! (the price was acceptable for just replacing them) :)
However, I was first quoted $40 per spacer and so if forced in that direction I probably would've tried harder to find the right (hardened steel) shims/thick washers
Post Posted: Fri Dec 13, 2013 12:14 pm
Ive paid $35. For a part that holds your diff together just fine for majority of people its not at all expensive.
Users browsing this forum: No registered users and 177 guests
