It is currently Sat Oct 24, 2026 11:17 am
Vehicle: 89 Sierra Widetrack
Post Posted: Fri Dec 20, 2013 8:05 pm
Hi All, hoping someone can offer me their wisdom.
Currently trying to finish putting my sj50 back together after a rebuild with a g16b conversion but I seem to be having some issues.
Firstly the things that don't seem to be working:
Indicators using indicator stalk (they do work with the hazard switch)
Windscreen Wipers
Windscreen Washer
Heating fan / blower
No fuses are blown.
Everything else seems to be working so I'm really confused why the items above won't get power
Anyone have any ideas? Or does anyone have a wiring diagram for the standard engine?
Cheers,
Aaron
Post Posted: Sat Dec 21, 2013 6:16 am
How are you checking the fuses? are you using a test light on them to see if there is power getting there?
If you have power there start looking for power at the stalk, indicators will be a green wire from memory
Post Posted: Sat Dec 21, 2013 8:49 am
Hi Royce,
Yes all tested with a light.
The whole top row of fuses were working and the bottom had no power. This morning I took the fuse rail off and ran a wire from the top to the bottom and the bottom rail powered up. Is there a safe permanent fix for this?
Cheers Aaron
Post Posted: Sat Dec 21, 2013 9:59 am
you really need to search to find the diagram that tells you which fuse is which, some will only have power with the key on.
Maybe there is something wrong with your ignition switch but you need to know whats what first, not just poking wires in places
Vehicle: SWB Sierra
Post Posted: Sat Dec 21, 2013 10:42 am
Did you mess with the black/blue wire mentioned in the pjzook wiring diagram? Step no. 11. It powers the heater fuse and a few fuses for the combo switch.
Post Posted: Sat Dec 21, 2013 11:08 am
Suzuki Sierra WT 92
Headlight R / Headlight -L / tail stop/ hazard horn / radio cigar / ACC
IG Coil - Meter / heater / rear defg / wiper washer / turn back / Air con
I believe this is the correct layout.
Ill head outside and have a look at the ignition wires.
Cheers Guys
Post Posted: Sun Dec 22, 2013 5:33 pm
Well I found the issue. At one stage of its life the ignition had been rewired and this relay had been added.
Not sure what it actually does but when I added power everything started working
Post Posted: Sun Dec 22, 2013 5:51 pm
Ahhhhhhhhhhhh the joys of finding other people fixes :-)
Nice work mate in finding the issue :-)
Users browsing this forum: No registered users and 206 guests
