It is currently Thu Oct 29, 2026 2:53 pm
Vehicle: 95 Vitara Hardtop
Post Posted: Thu Dec 26, 2013 11:16 am
A few months ago I got my gearbox rebuilt cos it was noisy in 3rd and 5th and had a few other niggling issues.
Went back in and it was much quieter, but occasionally after braking for a corner I noticed the same noise in the box when accelerating again, almost like part of the box was temporarily starved of oil, and now it seems like the noise in 3rd is just starting to come back, although not nearly as bad as it was, so;
- Has anyone else experienced this issue?
- Is it worth trying to get some extra oil into the box? (This was a fix for Lada Niva gearbox issues).
- Is it worth putting an additive into it, and if so is the Nulon one suggested in another post still worth trying?
I used the recommended grade of gear oil and it's Caltex brand so hoping it would be half decent.
I have an oil pump to fill the gearbox thru the filler plug, pretty sure it was filled at least to the filler plug level.
Thanks for any input.
Mike.
Vehicle: 1985 lwb sierra UTE
Post Posted: Thu Dec 26, 2013 12:01 pm
I use some additive and mines gone quite, even quieter since I replaced all seals for some reason :?:
Post Posted: Thu Dec 26, 2013 12:23 pm
Try using Penrite oil. If that doesn't shut it up then add the additive
Post Posted: Thu Dec 26, 2013 12:31 pm
As a general rule I would advise against putting more oil in a gearbox then is recommended. It 'could' put extra strain on your seals and blow them out if you put to much in but I do stand to be corrected if gwagen has a better idea :D
Post Posted: Thu Dec 26, 2013 12:47 pm
Yer extra oil the required is not good .100/200ml extra probably wont hurt
Vehicle: 09 Jimny JX
Post Posted: Thu Dec 26, 2013 1:28 pm
the Subaru world swear by the additive Nulon G70.
i am running Penrite oil and Nulon G70 in the diffs/ gearbox and transfer case..
Post Posted: Thu Dec 26, 2013 1:50 pm
What subara ?
Post Posted: Thu Dec 26, 2013 1:56 pm
Fill it with grease.
Post Posted: Thu Dec 26, 2013 2:58 pm
I ran Castrol synthetic gear oil and Nulon G70 in my Jimny when I was a courier, which saw roughly 1500 gear changes a day. It never gave a peep in over 100,000 k's.
My first experience with G70 was in my combo gear box, before I got the Jimny, it started making noise so I added G70 and it shut up for another 10,000k's then spat the main shaft through the end of the box, through the clutch into the fly wheel. Since then I swear by the stuff and it goes in all of my gear trains.
Post Posted: Thu Dec 26, 2013 4:58 pm
Yer I use g70 in my tcase , diffs, and gearbox. Great stuff
Post Posted: Thu Dec 26, 2013 5:19 pm
VMX80
Vehicle: 92 sierra tintop, 88 WT sj50
Post Posted: Thu Dec 26, 2013 6:56 pm
Try Lucas Oil stabilizer additive
It shut up my transfer case whine for a few months
Post Posted: Thu Dec 26, 2013 7:51 pm
I put this in the swift
http://www.redlineoil.com/product.aspx?product=50204
I wouldn't of said there was anything wrong with the box before but its a lot lot quieter now, its not cheap though.
Vehicle: 96 SV620 shitbox
Post Posted: Thu Dec 26, 2013 8:17 pm
Bruce wrote:
VMX80
I have never used anything else but castrol, VMX80 would be the best to use.
Not a fan of additives but the G70 has proven to work, usually the noises are from the bearings.
I've used it in several diffs that were noisy and it does shut it up..
Post Posted: Thu Dec 26, 2013 8:23 pm
offroadjack wrote:
Bruce wrote:
VMX80
I use vmx 80 and an additive in my gearbox as it developed a noise soon after I bought the car and its been quite ever since.my car does 60km a day
Post Posted: Fri Dec 27, 2013 6:10 pm
Thanks for all the replies, I will try the G70 additive for now, and look for some better gear oil for the next oil change.
Post Posted: Fri Dec 27, 2013 8:05 pm
Just a reminder that you need to use the additive every time you change your oil...40.000 k's intervals
Users browsing this forum: Google [Bot] and 408 guests
