It is currently Fri Nov 13, 2026 8:17 am
Post new topic Reply to topic  [ 499 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 17  Next
Post Posted: Tue Dec 17, 2013 2:56 pm
Finished the internal framing, including added cross beams on rear, to support the door hinges.
Got the front panels fitted.
May get started on framing rear door next, so it don't warp before I ready to fit it.
Post Posted: Tue Dec 17, 2013 2:58 pm
Was in the process of removing the rear panels, so I could glue n screw them.
But the excess glue from the frame work had stuck them on fast.
So I accepted that as done, and moved on.
I am a bit excessive with glue I think.
Vehicle: sj51
Post Posted: Tue Dec 17, 2013 3:21 pm
coming along well mate, im looking forward to the finished product
Vehicle: 1992 sierra
Post Posted: Tue Dec 17, 2013 9:50 pm
Liking how this is coming along 8)
Earlier in your thread I expressed an interest in doing this, gone now :(
Unless I obtain another trailer that is.
I assumed ( I know, stupid) that this would be removable. :oops: :oops:
My trailer is a much needed item, a project is not what it ( or I ) need
Post Posted: Wed Dec 18, 2013 4:58 am
No reason why you couldn't make a removable one.
Or a bolt onto the top of trailer version.
Both of which I considered.
Also considered a bolt on hard shell camper top,
but when I was out looking at them, I spotted a T-van, which cemented my desire for a teardrop type van.
Vehicle: Suzuki Sierra
Post Posted: Wed Dec 18, 2013 8:23 am
I'm thinking you might need a rib running across the whole roof, side to side in at least one spot.
There's a fair bot of weight to move around attached to a timber frame. Might event want to do something a little further down the wall.
Post Posted: Wed Dec 18, 2013 9:38 am
I need to get my arse into gear and finish my Kombi, not start another project :roll: :oops:
Making it removable adds a lot of extra dramas
The reason for wanting to build one of these is the challenge of doing it. 8)
Post Posted: Wed Dec 18, 2013 9:47 am
Roof piece should only be around 10kg.
But I will have room for more cross bracing if needed.
Will look into that as I go.
There is still more internal panelling to go in, which will also help with structure.
Am considering an arch shaped ceiling.
Challenge is a definite part of doing anything, but would buy a t Van if I could :)
I'm trying to keep it as simple as I can, for weight, cost and work load.
Post Posted: Fri Dec 20, 2013 3:49 pm
Finished the panelling, in between air con and drink breaks.
Was a bit hot today, but I already had one slack day inside.
Nothing is square, I expected that, but all was much squarer than I thought it would be.
Will still be able to hide any oopses all behind some strapping :)
Had some glue / sealer left so I filled a few of the screw holes.
Windows, vents and rear door next, or maybe finish the paint the inside.
Post Posted: Sat Dec 21, 2013 6:40 pm
So cosy
Post Posted: Sat Dec 21, 2013 7:10 pm
So cosy
I hope I stop farting before I fit up the rear door :mrgreen:
Thinking a futon mattress, had one years ago, and I loved it.
Post Posted: Sat Dec 21, 2013 8:13 pm
Lol you definitely should stop farting.
Futon is very heavy, I have one in our camper and want to swap to foam. The futon retains moisture too :(
Post Posted: Sun Dec 22, 2013 4:44 am
I'll give that a miss then.
Post Posted: Sun Dec 22, 2013 3:40 pm
Was planning to cut the windows and the holes for them, but I got started on back door instead.
Main reason being, I was scared of stuffing up the cuts, so I figured do the rear door first, :oops:
as I can fix that more easily, if I get it wrong :mrgreen:
Then I'll feel more motivated to cut holes into sides of the camper.
May add some extra framing up front, after window holes are in, if it is needed.
No big days at the moment, neighbours deserve a bit of a break from noise due to the hangover season. :beer:
Post Posted: Sun Dec 22, 2013 3:42 pm
May get more beefier hinges later, they looked stronger in the packet than they do fitted.
Post Posted: Sun Dec 22, 2013 7:26 pm
What colour will you paint the outside?
Post Posted: Mon Dec 23, 2013 4:42 am
Still arguing with myself over color.
Red to match Vit would look schmick, but white reflects heat better.
White would show muck.
Darker colors lessen the life of plywood (according to wood experts)
And what happens if my next car is a different color (Could repaint I guess)
At the moment I'm thinking white from top down to the guards area, and the rest red (which is mostly the metal bits.)
Or a white roof with red sides.
Or yellow to match my new portable radio pompoms
Post Posted: Mon Dec 23, 2013 5:47 am
I hope no lowlife locks you in and steals your car.
Post Posted: Mon Dec 23, 2013 2:47 pm
Made a start on the windows, and their holes.
Perspex cutting went better than expected, which was a relief.
But the window would not go into the rubber molding , no matter what I tried.
Either too small of a window for big rubber, or I need different rubber,
or a different plan.
Look into that later,
but may go back to original plan of incorporating windows into framing, with some pretty cover straps.
Vehicle: Black '96 X-90
Post Posted: Mon Dec 23, 2013 4:04 pm
Are you planning to keep the Suzuki badge on it? :P
Post Posted: Mon Dec 23, 2013 5:31 pm
Yes, and other related objects 8)
Post Posted: Thu Dec 26, 2013 3:01 pm
Framing finished and window holes cut today.
Have to decide on vents positions,
then it will be time for internal painting and underfloor tar paint.
Vehicle: Suzuki Jimny 2009
Post Posted: Thu Dec 26, 2013 8:13 pm
Great progress Chris. You seem to be progressing faster now you have the garage back. Are you planning on having it ready for the high country trip in January?
Vehicle: 96 SV620 shitbox
Post Posted: Thu Dec 26, 2013 8:27 pm
[quote="christover1"]Framing finished and window holes cut today.
Starting to look Schlick !
How about them wirly twirlers you see on them dog trailers?, that would keep the heat out...
Post Posted: Thu Dec 26, 2013 8:33 pm
That would be good, but is unlikely.
Could be close.
Getting stuck into it while health is good, and I don't have any appointments..
Post Posted: Thu Dec 26, 2013 8:35 pm
Yeah that is a maybe, and possible a solar charged fan type.
Trying to keep stuff off the roof , if possible.
Placing two vents up high and two down low.
Vehicle: SJ51T
Post Posted: Fri Dec 27, 2013 7:35 pm
Remember chris that windows allow you to see all the dodgy people creeping up on you, but it also allows dodgy people to see all the creepy things you are doing in there.
Post Posted: Fri Dec 27, 2013 7:52 pm
Anything solar charged is a bonus but not doing anything when the shiny thing goes down..
1 or 2 of those spinners on the roof will suck the heat out..
Post Posted: Fri Dec 27, 2013 7:54 pm
A fan is just circulating the heat around, you need an outlet for the heat.
Post Posted: Fri Dec 27, 2013 8:00 pm
I'm doing a similar thing to my 5x3 but just to pack/store camping gear etc.
Mainly because I have 3 dogs and 2 kids to tag along as well.
Trailer +roof storage should do, done it traveling to straddie that way ;-)
