It is currently Thu Oct 08, 2026 3:35 am
Vehicle: Sierra
Post Posted: Fri Jan 10, 2014 12:10 pm
So in my 89 Sierra the speedo doesnt work, has been so for a while.
being a newbie to the practical side of mechanical work (have done my reading) its things like this i need help with. So i found the speedo cable, and on the transfer case end it is wobbly and i can jiggle it around, like its not sitting correctly.
WOuld this be whats wrong?
Vehicle: 89 Sierra Widetrack
Post Posted: Fri Jan 10, 2014 3:09 pm
Could be a couple of things.
My last cable stretched somehow and the pin was no longer sitting in the back of the speedo.
Your cable could be damaged and no longer spinning or it could simply be disconnected behing your cluster. Just pop it out and have a look only 4 screws.
Easy to replace and a new one from ebay is cheap.
http://www.ebay.com.au/itm/Speedo-Cable ... 35a8fa8172
Just undo one bolt and its just a matter of threading it back under the body and into the cab and through the dash.
Hope this helps.
Cheers,
Aaron
Users browsing this forum: Google Adsense [Bot] and 47 guests
