It is currently Tue Aug 04, 2026 1:58 am
Post Posted: Fri Jan 17, 2014 3:15 pm
I have just obtained a 1998 Grand Vitara V6 2.5lt and when cold the idle revs fluctuate - Could this be a sensor problem and if so which one.
If not a sensor ??????????? Any ideas?
Post Posted: Sat Jan 18, 2014 6:26 am
I would suspect a vacuum leak or a bad O2 sensor.
Post Posted: Sat Jan 18, 2014 6:35 am
Thanks Rinomahn - Where is the O2 sensor - I don't have a manual yet. Can I test it or is it just replace and see?
Tony
Post Posted: Sat Jan 18, 2014 6:37 am
You will have two, one in each downpipe, haven't you got a scan tool? check the fuel trims.
Post Posted: Sat Jan 18, 2014 6:45 am
Yes I have the one from you but do not have the car yet - Does the lead fit this model? - I have the lead and extra plug.
Tony
Post Posted: Sat Jan 18, 2014 8:13 pm
If you remove the O2 sensors to look at them you may as well replace them, they don't like to be touched have a tendency to die when removed. Lead fitting will depend on what year it was bought for i believe the plug changed a bit in 03+. Also have a look at your air filter and change it if you do the O2 sensors.
Post Posted: Sun Jan 19, 2014 12:06 am
Yes it will work on that model, you can also use the controls to quickly check the ISC and the EGR. The GV FSM gives a list of the data values that should be expected at normal and fast idle.
Post Posted: Sun Jan 19, 2014 6:41 am
Thank you I will get the car home next week (I hope) and check it out.
Cheers - Tony
Post Posted: Fri Jan 31, 2014 3:49 pm
High all - I have just picked this car up and driven it 700ks to get it home.
The problem is more than just idle fluctuation - When it is driven, unless it is gently pulling as in a long hill or accelerating, the engine shunts as if the fuel or spark was being turned off and on. This happens once the car reaches the cruse speed you have pressed the throttle too, press more and make the car accelerate and it runs fine until the new curse speed is reached. If thee speed is taken to 115kph on the flat then it is OK until you lower the speed again.
Any help/ideas please as beside this problem the car passed rego and is in great shape.
Post Posted: Sat Feb 01, 2014 10:56 am
O2 sensor, possibly caused by a catalytic converter that is either on the way out or cactus. I had all sort of running issues similar to this after I crunched my catalytic converter on a rock and mangled the internals.
If you pull out the O2 sensor on the catalytic convertor and look inside it should be nice and honeycomb looking iirc (google will probaby have a better description/picture).
You can also test the o2 sensor but I've never had much sucess with this probaby because its not made of timber and I can't hit it with a hammer! (and I suck when it comes to electricky stuff)
Dave
Post Posted: Sat Feb 01, 2014 11:53 am
Thank you Dave for the reply - I know how you feel with the timber thing (I am/was a chippy as well) - Where can I find the test procedure for the 02 sensor?
Tony
Post Posted: Sat Feb 01, 2014 1:03 pm
viewtopic.php?f=5&t=38082&p=696358&hilit=grand+vitara+service+manual#p696358
Post Posted: Sat Feb 01, 2014 1:05 pm
That is the factory manual for the later models but the testing bit is the same i think. (i am happy to be corrected tho!)
Post Posted: Sat Feb 01, 2014 10:33 pm
Let it idle until it gets up to temperature and then scan it and post the data.
Post Posted: Sun Feb 02, 2014 6:31 am
Thanks Rinoman - I am 67 and this is all "White man's Magic" to me. I will try and get that done today.
Tony
Post Posted: Wed Feb 05, 2014 1:57 pm
Test 2
Vehicle: Which one?
Post Posted: Wed Feb 05, 2014 1:58 pm
tonyevans wrote:
Test 2
Double success!! Armsup
Post Posted: Wed Feb 05, 2014 1:59 pm
That worked but other attempts don't for some reason
Post Posted: Wed Feb 05, 2014 2:02 pm
There seems to be something in the data I want to post it does not like?
Users browsing this forum: No registered users and 60 guests
