| Author |
Message |
petes 80
Joined: Sat Feb 08, 2014 8:28 pm Posts: 95 Location: Morayfield, Qld
Vehicle: Suzuki Jimny 2003
 Posted: Mon Feb 24, 2014 4:59 am |
Hi all,
I picked up a new sierra on Friday and we took it out on the weekend. Everything was great except I couldn't get it into 4low. Is there a trick to it or would the problem be deeper?
Thanks in advance for any feedback
Pete
HarryHoudini
Joined: Fri Jul 01, 2011 12:34 am Posts: 359 Location: Northern NSW Australia.
Vehicle: Coily.
 Posted: Mon Feb 24, 2014 8:11 am |
No trick,it just a push forward,mine is very easy between high & low range but doesn't want to go back into 2WD once you select 4WD,can take 5- 10 mins. of jigggling to get it back. Sorry i can't be of assistance but there is obviously something wrong with your TC.
coily96
Joined: Wed May 05, 2010 11:50 am Posts: 823 Location: Beenleigh
Vehicle: Coil Sierra
 Posted: Mon Feb 24, 2014 6:32 pm |
Mine did that because the stick bent and would hit on the square cutout in tunnel before it selected low.
Fix is to remove knob, boot and look down when trying to select low, if it touches the tunnel its bent. It can bend from forcing it into low or 2wd high.
Put mine back into shape in a vice and a BFH. While its out lube up the cup it sits into. The split pin can be a pain to put back in.
coily96
 Posted: Mon Feb 24, 2014 6:34 pm |
If the stick is having trouble moving left to right or back into 2wd try flexing it up on uneven ground.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13008 Location: Melbourne
 Posted: Mon Feb 24, 2014 7:16 pm |
HarryHoudini wrote: ….. but doesn't want to go back into 2WD once you select 4WD,can take 5- 10 mins. of jigggling to get it back. Sorry for the hijack (sort of) but this raises a couple of other issues. What you're describing is transmission wind-up. If it's hard to get the car out of 4WD, you've driven on a high traction surface for at least a little while, and there's lots of tension on the transfer main shaft (between the front and rear outputs) That's an indication you're probably not shifting out of 4WD soon enough. if the surface is hard enough to cause wind up, you don't need to be in 4WD (that's my guide) In fact, I don't recall the last time I used high range 4WD. I go straight from 2WD to 4WD low. I also don't like the way the car handles in high range 4WD - really dead and soggy steering response. Secondly, if you are having this problem, reverse and squirm the steering left to right as you back up. Keep reversing and squirming until it goes smoothly into 2WD. Just some ideas. Steve.
HarryHoudini
Vehicle: Coily.
 Posted: Mon Feb 24, 2014 8:30 pm |
petes 80
 Posted: Tue Feb 25, 2014 5:42 am |
Ok, Thanks for the feedback, I will have a look at it tonight and see if I can fix it, otherwise I will take it back to the car yard and get them to fix it for me Cheers Pete
jimny_timmy
Vehicle: Suzuki Jimny 2010
 Posted: Tue Feb 25, 2014 7:14 pm |
The bush under the stick isn't munted or missing is it? This is quite common...
Reubs
Joined: Wed Sep 09, 2009 11:30 pm Posts: 1522 Location: Brisbane
Vehicle: SJ80, SE416
 Posted: Tue Feb 25, 2014 7:38 pm |
jimny_timmy wrote: The bush under the stick isn't munted or missing is it? This is quite common... Coily transfers don't suffer from that problem due to differences in design.
jimny_timmy
 Posted: Tue Feb 25, 2014 7:39 pm |
Reubs
 Posted: Tue Feb 25, 2014 7:59 pm |
jimny_timmy wrote: Possible case swap? Could be hey...
jimny_timmy
 Posted: Tue Feb 25, 2014 8:00 pm |
I wouldn't even know how to tell hahaha can anyone help the op in identifying the cases to rule this out?
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Tue Feb 25, 2014 8:20 pm |
Has it go a body lift?
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
coily96
 Posted: Tue Feb 25, 2014 10:08 pm |
Look where the transfer stick meets the transfer case, SJ80 will have the stick attached to an arm by split pin and it sits in a cup right at the end. SJ70 or ealier will go directly into the transfer (like a top loader gearbox). Its held in my a locking cap, spring and bush. You turn the cap and it pops off.
petes 80
 Posted: Wed Feb 26, 2014 6:58 am |
thanks guys, there is no body lift on it. I am going to take it back to the car yard and get them to fix it as it is peeing me off cheers
Damian
Vehicle: suzuki sierra
 Posted: Thu Oct 02, 2014 8:14 pm |
My sj80 also struggles to get out of 4wd and keeps piping out of 4 low and does hit the top of the cut out. I now know that my gear stick is bent and know how to fix it thanks but is this a problem all sj80s have ?
coily96
 Posted: Thu Oct 02, 2014 9:09 pm |
The transfer stick could be bent, possible from forcing it to hard forward.
You need to remove it from above and bend the stick backwards in a vice. Re fit and see if it still hits the square cut out in the tunnel.
Put some grease in the cup and ball on the end of the stick.
