It is currently Mon Sep 21, 2026 2:24 pm
Post Posted: Fri Aug 21, 2009 2:53 am
Can someone tell me what is the difference in MM is between the Wide track and the Standard Track?
Vehicle: Clown Car..
Post Posted: Fri Aug 21, 2009 3:00 am
try a search for WT NT differences.. Bog Frogs thread has a HEAP of useful info..
Post Posted: Fri Aug 21, 2009 3:24 am
wide track has wider diffs narow track has narow diffs capish? :no: :finger:
 Profile YIM
Post Posted: Fri Aug 21, 2009 3:28 am
isnt it wide track has wide track diffs.. the rest are just a 'standard track'!?
Post Posted: Fri Aug 21, 2009 4:55 am
i get that 1 is wider than the other, but by how much in millimeters. And what do they come out of?
lesspostingmorewheeling
Post Posted: Fri Aug 21, 2009 5:08 am
wide tracks were made from half way through 1988 to halfway through 1996 the most obvious way to tell them apart is the wide tracks have metal flares whereas narrow tracks have rubber flares and WTs have plastic corners on the bumpers that NTs don't have
Post Posted: Fri Aug 21, 2009 6:15 am
ahhh ok!
thanks heaps for the info!
Post Posted: Fri Aug 21, 2009 10:42 am
Track widths wms - wms
NT
Front 49 WMS
Rear 49 WMS
WT
Front 52 WMS
Rear 52 WMS
My Maruti build, Click WWW
Post Posted: Fri Aug 21, 2009 1:07 pm
Widetracks rule. :lol:
Post Posted: Fri Aug 21, 2009 1:14 pm
hay BlueSuzy has it got the plastic W/T wheel arch flares?
Post Posted: Fri Aug 21, 2009 1:17 pm
Topic turn* Sori :oops:
Havent seen it yet! They look rusty in pics so im guessing its metal :lol:
Post Posted: Fri Aug 21, 2009 1:39 pm
opps i dunno how that happened. the question was meant to be in this thread. :oops:
http://www.auszookers.com/index.php?nam ... pic&t=6005
Post Posted: Fri Aug 21, 2009 2:18 pm
silly shep :lol:
Post Posted: Fri Aug 21, 2009 4:46 pm
xedent,
thanks for the specs. Big help!!
what does WMS acctually stand for?
Post Posted: Fri Aug 21, 2009 4:52 pm
WMS = wheel mounting surface
There is about 90mm difference between the narrow track and the wide track.
Vehicle: I drive your mum
Post Posted: Fri Aug 21, 2009 4:53 pm
4WD4LIFE wrote:
xedent,
Wheel Mounting Surface. Basically the flat surface on the hub that the wheel sits against.
Layto....
Post Posted: Fri Aug 21, 2009 5:04 pm
NT
Front 49 WMS
Rear 49 WMS
WT
Front 52 WMS
Rear 52 WMS
Guessing that is in inches ??
Post Posted: Fri Aug 21, 2009 11:42 pm
Im looking at getting an 88 ute, would this be a WT?? i saw someone saying that that half way thru 88 they were WT, Im just wondering if its the same with the utes.
Post Posted: Sat Aug 22, 2009 10:43 pm
Some comparisons:
The following table is for Front track (track = centreline of tyre to tyre), rear track and wheelbase (front axle to rear axle):
LJ20 F 1090mm R 1100mm W/B 1930mm
LJ50 F 1090mm R 1100mm W/B 1930mm
LJ80 F 1190mm R 1200mm W/B 1930mm
LJ81 F 1190mm R 1200mm W/B 2200mm (Ute)
SJ40 F 1210mm R 1220mm W/B 2030mm *
SJ40 F 1210mm R 1220mm W/B 2375mm (LWB +Ute)
SJ50 F 1210mm R 1220mm W/B 2030mm **
SJ50 F 1210mm R 1220mm W/B 2375mm (LWB + Ute)
SJ70 F 1300mm R 1310mm W/B 2030mm
SE416 F 1395mm R 1400mm W/B 2200mm (Vitara)
* The SJ40 (1.0lt Sierra) was available with either 6.00-16 bar treads or FR78-15 on sunraysia type rims. Subtract 20mm from track for 6.00-16, and the track is the same as for LJ80/81.
** The SJ50 was available as the Narrow track or the first type Wide Track. The figures here represent the N/T specs. SJ70 specs are the same as for SJ50 W/T.
Post Posted: Sat Aug 22, 2009 10:46 pm
The Utility was only Narrow Track, but the LWB was produced in Wide Track. The Ute was Discontinued in 87, and the LWB in 88, but demand from farmers for an Ag vehicle saw the Maruti introduced as a N/T LWB in 88 and conversions were done to these to fit an alloy tray, effectively making them a "Ute".
Post Posted: Mon Aug 24, 2009 12:48 pm
My 88 WT LWB Was built in Janurary. Genuine Suzuki. Not Maruti. They also call them an SJ51 on the build plate. Not SJ50.
Post Posted: Tue Aug 25, 2009 10:05 am
Well, I did say that 88 was the last year for the Suzuki LWB W/T, didn't I??
Danno was talking about an "88 Ute", and Suzuki had discontinued the Ute in 87 (which was an N/t), and brought in the N/T Maruti to do alloy tray conversions to. I don't believe any of the Suzuki-made W/T LWBs were converted into tray-top Utes.
Vehicle: 1993 Suzuki Vitara 4dr Wgn
Post Posted: Fri Apr 18, 2025 5:25 pm
The Maruti ute from India - what year did it stop coming into Australia?
Were ALL Maruti Utes "NT's" or were the later ones WT?
'93 4Dr Vit, Red Gears,Bighorn 30" MTs, Sliders:B/
Post Posted: Fri Apr 18, 2025 7:22 pm
Later one were WT.
Users browsing this forum: Bing [Bot] and 143 guests
