It is currently Fri Nov 13, 2026 10:30 am
Vehicle: jimny
Post Posted: Tue Apr 01, 2014 6:19 pm
'96 vitara 16v g16b engine with microtec computer and book,
comes also with extractors, bolted to the engine is the vitara gearbox minus the transfer
there is a modified shortened jack shaft which couples the box to your sierra
transfer case, the engine also has power steering setup on it and power steer box
with pitman arm and piping all this came out of a sj51 sierra. the engine is a dizzy type with
angle drive on back of head will need to organise your own electric fuel pump but every
thing else is there ready to go relays and all they are all marked
Price$1850 neg
location katoomba nsw
phone 0421 67 00 22
can separate parts if required SOLD SOLD SOLD
Vehicle: 1996 Leaf Sierra - Soft Top
Post Posted: Wed Apr 02, 2014 5:30 pm
Would this suit a 96 leaf sprung sierra?, would by the sounds if it. How many KMs are on it and would you organize post/ courier to ACT, 2605
Vehicle: Drover pickup turk
Post Posted: Wed Apr 02, 2014 5:53 pm
Manual or auto gearbox? Price without power steering setup?
Has the computer been set up properly?
EDIT: Got my answers. :D
I like the tuna here
Vehicle: jimny
Post Posted: Fri Apr 04, 2014 4:24 pm
Sorry for taking so long to reply been a busy week the engine will go into a 96sierra the gearbox requires cross member brackets welded on and gearstick relocation the sierra i got it out of had a hole cut for gearstick and the old hole welded up not sure what the benefit of running a vitara gearbox was maybe better ratios for simplicity id just use an adapter plate and mount the engine to your original gearbox. the ecu not sure what tune it has but it was running fine was very strong performane the computer comes with the manual and serial cable for a pc. the gearbox os manual. i will try to pics up this weekend and i will try and organise a fuel pump and tank so i can demonastrate it. $1300 with no power steer setup, $1100 engine alone
Post Posted: Sun Apr 06, 2014 7:31 am
Okay great! Pictures would be good.
Do you know how many KMs are on the engine??
Vehicle: jimny
Post Posted: Tue Apr 08, 2014 6:37 pm
Not sure of kays at all unfortunately hopefully thisweekend get some pics up
Vehicle: jimny
Post Posted: Fri Apr 11, 2014 10:46 pm
Sold sold sold
Users browsing this forum: No registered users and 7 guests
