It is currently Thu Nov 05, 2026 11:48 am
Post new topic Reply to topic  [ 553 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 19  Next
Post Posted: Sun Jan 19, 2014 6:43 am
That sucks. Have you gone back through the thread? The check engine light has definitely been talked about, not so sure about the immobiliser light and speedo. Do you have a OBD reader?
Vehicle: 2008 Jimny Standard As :-)
Post Posted: Sun Jan 19, 2014 6:55 am
Found it, missed a small earth wire towards the back of the motor.
She's running sweet, just have to put in my M18a injectors.
Post Posted: Sun Jan 19, 2014 8:28 am
Good job!
Post Posted: Sun Jan 19, 2014 9:06 am
Good job!
Impressed with the performance so far but I haven't driven much.
Next one your mod list ZN?
Post Posted: Sun Jan 19, 2014 10:39 am
I'll be hunting down a 1.5 soon. I don't mind the idea of the 1.8 but I only need a small amount of extra power. Actually it's really just a bit more torque that I'm after. 1.5s are so easy to find with low kms and cheap.
My 1.3 is running well at the moment and nobody want them so I have trouble with the idea of throwing away a perfectly good engine.
Post Posted: Sun Jan 19, 2014 10:40 am
+ I just ordered a new welder so my spending needs to go on hold
Post Posted: Sun Jan 19, 2014 10:59 am
Yeah I looked at a 1.5 wreckers here wanted $950 and I got my 1.8 for less.
Just got a check engine light and a air sucking sound coming from the engine and it started running real rough.
It's sucking air so we are about to start troubleshooting.
Post Posted: Sun Jan 19, 2014 11:53 am
So thought I'd share my problem.
One of the o rings split around the injector!
Post Posted: Sun Jan 19, 2014 2:57 pm
Can you use one from the 1.3?
Post Posted: Sun Jan 19, 2014 3:50 pm
All good, I had used the 1.3 injectors instead of the 1.8 I have swapped them over now.
Engine running sweet, I can over take cars now !
Vehicle: 2011 Jimny
Post Posted: Sun Jan 19, 2014 10:57 pm
whats like at speed? still sit on the same revs and still get some pull out of it when you put the foot down
Post Posted: Mon Jan 20, 2014 6:48 am
^^ For sure
Vehicle: Jimny 2001
Post Posted: Tue Jan 21, 2014 12:18 pm
Hi just got my self a 2001 jimny, I believe it's a non vvt 1.3 what the best engine I can replace it with, 1.6 liana non vvt? Can I put a 1.8 in it?
Vehicle: jimny g13bb, 99 wrx!
Post Posted: Wed Jan 22, 2014 11:06 am
Curious as to wether theres a motor to suit the 2013 facelift that still complies with all road rules ect in vic. Pretty sure one of vics laws is the motor has to comply with adr, emmissions, be same year or newer and also have no structural or engine mount mods to be able to be signed off by a vicroads rep.
Could be in the market for a newy soon
Post Posted: Wed Jan 22, 2014 1:23 pm
3400rpm @ 110
Yeah goes well, I just replaced the viscus fan so now I can really test it.
Vehicle: On the lookout
Post Posted: Fri Jan 24, 2014 12:53 pm
Get an M15 from a Swift, July 2008 or newer. I could write a whole couple of boring paragraphs why but if you are interested just PM me or take my word for it or use the search function, I'm sure I've posted a couple of times on this subject regarding emmisions and ADR's in depth.
Vehicle: Sj70 tintop
Post Posted: Sat Jan 25, 2014 3:08 pm
is it really that worth it though??
does the extra 200ml capacity really overshadow the pissy 1.3 that much to make it all worth it.??
Vehicle: Suzuki Jimny 2011
Post Posted: Sat Apr 12, 2014 9:16 pm
Thanks guys Due to this thread l have source a m18a engine and put it in my Jimny. I sorted the idle problem on the m18 throttle body so I keep the m18 intake manifold and throttle body . The engine running smooth like the m13.
The high idle as due to a stuck idle control valve the stepper motor's bearing was seized or rusted. Clean oil and fit and my idling is fixed.
Post Posted: Sat Apr 12, 2014 9:53 pm
A little bit of discussion about using the 1.8 throttle body taken from Zukenutter's build thread. I thought it would be better to move this discussion back here with the rest of the M18 tech.
Is anybody running the 1.8 throttle body? If no, what is the issue with it?
JayKay wrote:
I didnt use it because of this in the Conversion thread
squibby wrote:
Also you WILL need to use the Jimny throttle body. You may think the Liana one is better because it is bigger, which is true, but the Jimny ECU will not run the Liana throttle body. The idle air control valve is much bigger on the Liana and you jimny will not idle properly.
Regarding fitting a freer flowing exhaust manifold - don't do it yet. get the engine conversion running on stock then change it after. It won't get you many gains anyway since you are still restricted by the smaller jimny throttle body.
Would swapping just the idle air control valve work?
tim80z wrote:
This is what happens if you put the 1.8 throttle body on:
Basically it runs great when you are on the throttle but as soon as you lift the throttle (about 0:03 in the vid) the idle oscillates. This is more of a pain when you are trying to just idle around a car park or in traffic because as soon as the throttle goes up you are propelled forward then it instantly drops back and you end up bouncing around like an idiot.
If you can figure out a way to make it work you will make lots of people happy. I've kept my 1.8 throttle body in the hope that I will be able to use it one day...
Hi Tim.
What about 1.8 throttle body with 1.3 idle air control valve?
Post Posted: Sat Apr 12, 2014 9:54 pm
OK, so I had a look at using the 1.3 idle air control valve on the 1.8 throttle body today. As it turns out the idle air control valve is different shape on each throttle body as shown in this picture:
The 1.3 throttle body is on the left and the 1.8 is on the right. The idle air control valve on the 1.3 is held on with 4 bolts and on the 1.8 its held on with 3 bolts.
My first thought was to make up an adapter but then I realised that the port size is very different between the two.
1.3
1.8
So now I have a new plan. I am going to make a spacer/adapter that mounts the 1.8 idle air control valve to the 1.8 throttle body but has a smaller port opening in it. Hopefully this will let me use the 1.8 throttle body without the oscillating idle issue in the video above. Hopefully I can make up the adapter this week and then install it over the Easter weekend.
Post Posted: Sat Apr 12, 2014 10:19 pm
Fingers crossed for you Tim. Thanks for having a go.
Post Posted: Sat Apr 12, 2014 11:05 pm
X2 buddy
Post Posted: Sun Apr 13, 2014 2:40 am
Tim
Take that black coil part of then you wil see a shaft piece with a permanent magnet on it , this shaft must rotate freely and smooth otherwise it wil not idle correctly mine was stuck . I have use the 1.3 coil part (black part) .( sorry for my english )
Vehicle: 06 jimny M18A..
Post Posted: Mon Apr 14, 2014 8:58 pm
Hi guys, I have the 1.8 throttle body on my car and have it idling exactly the same as with the 1.3 throttle fitted. What you have to do is remove the 1.3 idle speed control motor and fit it onto the 1.8 throttle body. Once fitted a 10-20 min drive in traffic and the idle will settle and be just as it was..
Post Posted: Mon Apr 14, 2014 9:05 pm
Thanks Dave
Post Posted: Mon Apr 14, 2014 9:18 pm
Thanks Bertie and Davesrt.
I am in the process of trying this but I had to buy some more tools to do the swap as the IAC valve motor is held on with 2 #20 5 point torx screws (not the usual 6 point torx).
I bought a set of 5 point torx today and have taken the 1.8 one apart for a look. I'll do the swap tomorrow or Wednesday and report back with pictures.
Post Posted: Mon Apr 14, 2014 9:45 pm
Waiting with anticipation
Post Posted: Wed Apr 16, 2014 9:01 pm
Great success!
I installed the M18A throttle body today with the IAC motor (the black part of the IAC valve) from the M13A and so far every thing is working properly.
The IAC motor is held on with 2 #20 5 point torx screws. I didn't have a set of 5 point torx drivers so used it as an excuse to buy more tools.
The two IAC motors look exactly the same but have different part numbers. The IAC motor from the M13A is the one you want to use and it has 18117-78F11 written on it.
The M18A IAC motor has 18137-54G10 written on it.
The top coolant pipe on the M18A throttle body is different to the one on the M13A so you will have to use the top hose from the M18A as well. You can see the difference in this picture:
I've only driven a few kms since installing the bigger throttle body but the difference is fantastic. The engine feels so much more responsive now, it is clear that the engine was heavily restricted with the 1.3 throttle body (no big surprise really).
Thanks again to Bertie and Davesrt for pointing me in this direction, it's good to finally have a solution for using the 1.8 throttle body.
Post Posted: Wed Apr 16, 2014 9:31 pm
Awe yeah, so trying this one the weekend !!
Post Posted: Thu Apr 17, 2014 7:06 am
Tim it is only a pleasure if it was not for this thread I was stil riding a 1300.
Users browsing this forum: No registered users and 31 guests
