It is currently Thu Nov 05, 2026 11:48 am
Post new topic Reply to topic  [ 553 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 19  Next
Post Posted: Thu Apr 17, 2014 7:44 am
M18A VVT shopping time for me :D
This could see a change in direction for my Jimny with a suspension drop of 20mm and a transfer sway to the non VVT transfer, then back to 235s. Gearing will be roughly equivalent to a stock Jim with 215s.
Thanks for testing this Tim and of course the input from you other guys. Great news, I'm excited!
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Apr 17, 2014 7:53 am
M18 throttle body issues sorted, so the next restriction is the standard jimny exhaust manifold or have peeps already been running extractors?
ZN, let me know if you find 2 :P
Post Posted: Thu Apr 17, 2014 8:52 am
Hard to find one, wishing I bought the one in Grafton a couple of months ago :(
Vehicle: 2008 Jimny Standard As :-)
Post Posted: Thu Apr 17, 2014 9:05 am
One here in TAS at a local wreckers.
but its a bit weathered :(
Post Posted: Thu Apr 17, 2014 10:55 am
There is probably still one at the local wreckers here in Parkes but the guy that runs it is a total douche. That said it only had around 18000kms and he wanted $1400 for it.
When I was looking for mine (and ready to buy) I put a request out on find a part (http://www.findapart.com.au/). I ended up with about 3 quotes later that day and another couple the next day.
This is old info now (July 2012) but may be useful for price/km comparisons:
Code:
Troubles Wrecking (VIC)      56000kms      $880     Delivery included
Parkes Wreckers (NSW)        18000kms     $1400     Local pickup
New Model Wreckers (NSW)     30000kms     $1250     + $80 delivery
New Model Wreckers (NSW)    100000kms      $880     + $80 delivery
Suzifour (NSW)               46986kms     $1650     + $100.00 to $198.00 delivery
Huge Auto Wreckers (VIC)       ???kms     $1100     + unknown delivery
Post Posted: Thu Apr 17, 2014 10:59 am
One here was $1100
I got mine for $770 with 110 thou ks
Post Posted: Thu Apr 17, 2014 11:15 am
I'm onto one that apparently has low kms but I can't confirm until I hook a battery up to it. I have to pull the donk myself too :(
Where'd you get that list Tim?
Post Posted: Thu Apr 17, 2014 11:28 am
Hopefully pulling the motor out yourself saves you some money.
That list is just the quotes I received when I was looking back in July 2012.
Post Posted: Thu Apr 17, 2014 11:59 am
Ok. I think that prices on the 1.8 have gone up. Swift tuners and Jimny tuners both want them and Lianas weren't a big seller compared to the Swift. I'll go check out the local one next week.
Post Posted: Thu Apr 17, 2014 1:30 pm
Got one lined up, probably pick up on Tuesday. $850 with 68,000kms
Time to read through this thread from the beginning again.
Post Posted: Thu Apr 17, 2014 2:03 pm
That seems like a pretty good deal. Any idea on when you are likely to do the swap?
Post Posted: Thu Apr 17, 2014 2:13 pm
I PDF'd the thread and stuck it on my iPad
Post Posted: Thu Apr 17, 2014 2:25 pm
The other one was a smudge cheaper but I'd have to pull it myself, that didn't excite me. I'd love to have it done next week for Anzac weekend away but won't have time so it will happen the following week. Very excited.
Good idea
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Apr 17, 2014 2:39 pm
buy you beer for making the most detailed conversion guide ever
Post Posted: Thu Apr 17, 2014 3:55 pm
Soon we will need "M18A Crew" Stickers ;)
Post Posted: Thu Apr 17, 2014 4:41 pm
I've got mine:
Post Posted: Thu Apr 17, 2014 10:33 pm
Oh I forgot about those.
Post Posted: Fri Apr 18, 2014 9:59 am
tim80z wrote:
Great success!
I installed the M18A throttle body today with the IAC motor (the black part of the IAC valve) from the M13A and so far every thing is working properly.
Hey man are you using the 1.8 manifold ?
Post Posted: Fri Apr 18, 2014 12:37 pm
I'm just using the 1.3 manifold based on this bit of Squibby's guide:
squibby wrote:
Some common misconseptions - you should use the jimny intake manifold NOT the liana. It has additional connections for the 4x4 vacuum hose, and other then this it appears to be the same size in everyother way. Don't think the liana one is bigger and more 'freer flowing - it isn't.
To be honest I didn't have a good look at the two for a side by side comparison when I was doing the swap and I no longer have the 1.8 manifold to compare to (sold it with the 1.3) so I can't confirm that this is true.
Post Posted: Fri Apr 18, 2014 3:07 pm
Yeah it's true, wonder if you could tap in another connection on the 1.8 manifold for the vacuum?
I just did the throttle body swap and confirm it's working the way Tim said !
Thanks for you help Tim!
Vehicle: Suzuki Jimny 2011
Post Posted: Fri Apr 18, 2014 4:32 pm
I have put the M18A manifold on mine there is a difference in diameter of the port between the m13 and m18 manifold the biggest difference is where fhe throttle body bolt on the manifold the m18 is much bigger.
To sort out the vacuum pipe issue I put a t piece in the vacuum line that go to the fuel pressure regulator and tap the vacuum for the 4x4 system there from.
Post Posted: Fri Apr 18, 2014 4:58 pm
i was thinking of trying that just before !
Vehicle: On the lookout
Post Posted: Tue Apr 22, 2014 10:58 am
That's out of date now Tim, I believe someone found that the ports are actually bigger on the M18.
Perhaps I should update the master thread now to refelct the M18 Throttle Body/Idle Control Valve and the new knowledge regarding the manifold?
I'll get onto it...
Post Posted: Wed Apr 23, 2014 4:46 pm
My 1.8 came with the loom all the way through the firewall. Did you guys strip the Liana loom and just plug the jimny loom into the 1.8?
Also, is anybody running the Liana flywheel? At first glance it looks heavier which I'm thinking will work well on the highway, plus I'm thinking the 1.8 will have plenty of pep so no need for a lighter flywheel.
I've been having a better look over it this arvo, the 1.8 throttle is quite a bit bigger. Made me wonder how running the 1.8 throttle body on a 1.3 would go, could be a good intermediate upgrade?
Post Posted: Wed Apr 23, 2014 5:07 pm
Yeah man use the 1.3 loom..
Not sure on the flywheel, my 1.8 was a auto.
TasZooks
http://www.facebook.com/TasZooks
Post Posted: Wed Apr 23, 2014 5:23 pm
I didn't get enough loom to use it and I didn't get a flywheel either.
I got rid of my 1.8 manifold when I sold the 1.3 so now I have to try and track one down so I can change it over. It will probably end up costing me more than the $50 I got for the engine though.
Post Posted: Wed Apr 23, 2014 8:17 pm
That's why I'm just going to mothball my 1.3. Just not worth selling. Such a shame that you only got $50. Maybe you could find a seized/damaged 1.8 for cheap.
I'll go ahead with the 1.8 flywheel, can't see why it wouldn't work. My clutch has only done 50,000kms so I'll just reuse it.
Post Posted: Thu May 01, 2014 8:04 am
Questions time
1. Connecting the air filter box to 1.8 throttle body, what's been done here?
2. Are there any gaskets I should buy prior to installation?
3. What is the issue with keeping the Liana rocker cover?
There will be more but this is what I have so far
Post Posted: Thu May 01, 2014 2:50 pm
Questions time
1. Nothing special, it fits.
2. Yeah, some Instant Gasket for the sump, you will be using the M13A sump, it uses instant gasket from factory
3. Liana rocker cover dipstick is in the wrong place.
Post Posted: Thu May 01, 2014 3:42 pm
Does it matter?
Users browsing this forum: No registered users and 31 guests
