It is currently Mon Aug 03, 2026 12:15 pm
Post Posted: Tue Apr 29, 2014 1:47 pm
OK - I have a welder that can be used for stick welding and/or TIG - Out where I live it is 75k to town to get a refill gas bottle and I would only use it now and then as I am used to stick and use that.
I now have an LJ50 body to cut out rust and weld in panels and while I am OK with stick I an' that goos on paper thin metal they make LJ's out of :?
My question is does anyone know how much welding you can do on light steel with a 2lt disposable bottle of gas?
Cheers for any help
Post Posted: Tue Apr 29, 2014 6:32 pm
Gas flow for tig is around 7 litres per minute.
Post Posted: Fri May 02, 2014 3:20 pm
NOT MUCH....
Tony how many cubic litres of gas are in the bottle?
As above mig gas flow is 5-15 litres per minute, depending on the job.
Post Posted: Sat May 03, 2014 8:05 am
Thanks Jason - I thought that may be the case - I will have to keep fighting with the gas-less MIG I guess :(
Post Posted: Sat May 03, 2014 8:48 am
If you don't want to drive the 75k regularly why don't you get the biggest bottle you can so replacements are like once every two or three years?
Post Posted: Sat May 03, 2014 9:08 am
The rental out here is more than the gas 8O
Vehicle: '96 LWB trayback
Post Posted: Sat May 03, 2014 11:46 am
Jump on ebay and look up seller "Atomic Gas Supplies" or "Speciality Gases"
Buy your own cylinder, and swap & go when you need it exchanged from a range of speed e gas and core gas outlets, or via mail.
D & E sizes available.
You pay more for a refill than a BOC cylinder etc, but it costs you nothing if it sits in the shed unused for a couple of years until your next project.
Post Posted: Sat May 03, 2014 3:36 pm
Had a look and can not find them???????????
Post Posted: Tue May 06, 2014 4:53 pm
I run 8-15 depending on the job/cup
Post Posted: Tue May 06, 2014 7:07 pm
Atomic website is under construction, all enquiries by email. Info@atomicgas.com.au
Coregas Speciality gases. http://www.coregas.com/index.php?option ... Itemid=172
Post Posted: Thu May 08, 2014 3:29 pm
Thanks Jason - I don't trust operations with websites like that :lol:
Post Posted: Thu May 08, 2014 3:51 pm
Definitely a valid business, it's been under construction for ~5 years at least. The owner of Atomic is a branch manager for one of the gas suppliers (speed-e gas I think). I've got 2 bottles through them and have had ~20 odd refills from them.
I'll find the phone number in a few weeks when I'm back in NSW.
Users browsing this forum: Google [Bot] and 30 guests
