It is currently Sat Sep 26, 2026 8:36 am
Post Posted: Wed Aug 26, 2009 12:37 am
hey i just installed a 1L case (with a 4WD activation light) into my 89 WT 1.3 sierra. I flogged the flanges off another 1.3 case i had laying around, and now none of the shafts line up? Is there any difference between a 1.3NT and a 1.3WT?
Post Posted: Wed Aug 26, 2009 12:46 am
early 1 litre, 1.3 NT and 1.3 WT are all different
late 1 litre (maruti) are the same as WT I think
Post Posted: Wed Aug 26, 2009 1:08 am
to make the 1ltr case work in the Wt you need to swap the case ends with 1ltr ones. This can be done but you need to use 2 halves of 2 different unis. Bearing caps are the same size but one has an external clip the other has an internal clip. Not that hard to make work. I ran it for years untill some propper gears came my way.
Post Posted: Wed Aug 26, 2009 1:59 am
Did you have one without the 4wd light or not? Mine splines are the same... but i havn't taken the hand brake off yet to see if the problem is how far it slides in... Im thinking it bolt's straight up... we'll see tomorrow
Post Posted: Wed Aug 26, 2009 2:59 am
had both. the switch type used NT patern and the non light one used the small flanges which needed the uni conversion.
Vehicle: Clown Car..
Post Posted: Wed Aug 26, 2009 11:56 pm
id suggest asome vmx80 and a new shifter bush to ;)
welcome to 1litre country :D
Post Posted: Thu Aug 27, 2009 12:39 am
the flanges you got off the other 1.3 must of been nt. pull the flanges from the case with the gears.
Users browsing this forum: No registered users and 42 guests
