It is currently Wed Oct 07, 2026 4:37 pm
Vehicle: 84 Lwb Ute
Post Posted: Sat Mar 24, 2012 9:21 am
Chasing some help. Currently just put a 1.3 in too my 1.0 and I'm up to wiring for the coil and alternator. As one is points and ones electronic coil can any one tell me what wires go where for the coil. Also the alternator wiring is different. Could any one help me out please. Regards
Vehicle: 84 Lwb Ute
Post Posted: Sat Mar 24, 2012 10:46 am
Any help asap would be great
Post Posted: Sat Mar 24, 2012 12:57 pm
Put the 1l dizzy in the 1.3 and the 1l alt on. Hey presto, no wiring changes! :)
Post Posted: Sat Mar 24, 2012 2:25 pm
Black and white wire on the ballast resistor goes to coil positive, dont use the ballast but do use a 1.3 coil
brown wire from teh dizzy also to coil positive, the other from the dizzy (maybe yellow) to coil negative
Alt is a pain in the ass to explain but
Fat wire, to teh stud on the alternator like usual
Get the 1.3 alt plug and plug it in, you have black and white wire and white and red from memory?
black and white on the plug hook to black and white on teh 1 litre loom
white and red on plug hook to white and GREEN on the 1 litre loom
Now under the glovebox is the alt regulator, 6 pin plug into a black box, remove the box and chuck it, cut the white and GREEN wire and white and RED wire from teh plug and join them together on the CAR SIDE of the loom
Should all work then
Vehicle: 84 Lwb Ute
Post Posted: Sat Mar 24, 2012 2:40 pm
Cheers people worked it all out. Thanks for your help :)
Vehicle: 89'SWBsierra&84'LWBsierra
Post Posted: Sun Nov 04, 2012 2:32 pm
hi guys
i found this topic after a search and thought it was close to what i am after. i have wired it up as royce explained but it still doesn't work. (my sierra is a 1.3L NT LWB with the standard 1.3L engine). i brought a 1.3L LWB sierra but it was in bits i have just got the 1.3L motor in and plugged up but i don't have any spark coming from the coil to the dizzy. i have tried a spare coil, checked for loose earths. not sure where to go from here.
another thing is if the cable from the alt to the battery is disconnected it won't turn over is this normal?
any ideas???????
thanks greg
Post Posted: Sun Nov 04, 2012 7:24 pm
another thing i don't have is the alt regulator box or a plug for it is this normal. i remember my old SWB sierra had one and it was also 1.3L?
thanks greg
Vehicle: suzuki lwb sierra
Post Posted: Tue May 13, 2014 5:23 pm
can i use a 1lt alternater and the 1.3lt coil?
Users browsing this forum: Google Adsense [Bot] and 122 guests
