It is currently Mon Sep 21, 2026 7:19 am
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2
Post Posted: Tue May 13, 2014 9:57 pm
Missed this thread from the start, interesting read. I'm an advocate of just using the receiver pin method. The HR tow bar is attached to the chassis at a few points and if you're using a strap of the correct rating for Jimny it'll fit in the 40mm hole. The bigger issue is recovery from the front.
Vehicle: Suzuki Jimny 2010
Post Posted: Tue May 13, 2014 9:58 pm
Agreed^^^
Vehicle: 2012 JIMNY SIERRA
Post Posted: Thu May 15, 2014 1:39 pm
Yeah I haven't used it a good point is just the snatchy with the pin through it I got an xrox up the front now with recovery points and a 9500lb winch in the bar to skull drag it out from the front. Thinking about getting some thing machined up from the back to but a shackle through for winch recoveries still use the pin for snatching though because of the unlikely event of the pin shearing. A decent rated soft sling choke/hitch would suffice if you really needed a shackle
Vehicle: Suzuki Jimny 2009
Post Posted: Sat May 17, 2014 8:46 pm
I did a calculation on the tow bar pin in a thread about a year or more ago. Because it is in "double sheer" and it is quite a big diameter it will not break with the force that any strap can apply.
Vehicle: Suzuki Jimny 2013
Post Posted: Mon May 19, 2014 10:07 pm
Just regarding the towing from the front, I recently sent an inquiry to APIO Japan regarding the 9mm steel plate they had available that can be mounted on the front of the Jimny... they wanted $158 including delivery, instant thought is it seems very expensive, with half that cost being shipping, but i guess It could be worth its weight in gold :P
Post Posted: Tue May 20, 2014 6:42 am
I was looking at those yesterday, wouldn't be hard to make them. Was $158 for a pair or just one?
Post Posted: Wed May 21, 2014 3:30 pm
Yeah I thought they looked fairly easy to make as well, if you know what you are doing :(
$158 was for a single Front Right tow hook... the shipping fees are pretty high.... I just did converted it on google.. has gone up a little... 15231 JPY = $163 AUD :o
The 9mm warm (bumper change car use) right (the driver's seat side) for APIO gym knee JB23 traction hook T9, fronts(3070-30R)
"This is the final adjusted quote of your ordered item, APIO towing hook plate, Right Side of vehicle. 3070-30R
Warning: if this is not the item you want, please let us know before you make the payment.
Item Cost 6376JPY
Shipping & Handling 8855JPY
Total 15231JPY
Vehicle: 91 Tin Top
Post Posted: Wed May 21, 2014 4:19 pm
1 x $20 rated tow hook, 2 x high tensile bolts (120mm long), a drill and no fab skills needed.......
$160 is a lot of money to reduce your approach angle, those bolt on plates hang soooo low.
Post Posted: Wed May 21, 2014 4:24 pm
^ did you plate it inside the chassis?
Vehicle: 91 Tin Top
Post Posted: Wed May 21, 2014 4:28 pm
Bolts go right through chassis rail with 3mm plates top and bottom.
Post Posted: Wed May 21, 2014 4:47 pm
I bought two of these hooks years ago, sitting in a box somewhere. Maybe I should dig them out.
I like the bolt right through, did you add crush tubes?
Vehicle: 91 Tin Top
Post Posted: Wed May 21, 2014 6:00 pm
Started this if you want more details how I did it....
http://www.auszookers.com/forum/viewtopic.php?f=14&t=46344
Vehicle: jimny g13bb, 99 wrx!
Post Posted: Mon Jun 16, 2014 6:47 pm
Im using ora front bolt ons. 6 m16 8.8 bolts total, 4 in the chassis and 2 between the brackets
Users browsing this forum: No registered users and 30 guests
