It is currently Tue Jul 28, 2026 7:16 pm
Post Posted: Mon Mar 07, 2011 6:14 am
The old girl has caster problems, it pulls to the left pretty bad even after the wheel alignment. I cant find any caster bolts or even camber bolts that have the bolt length and i dont know if the offset bushes like the ones from bits4vits fit the calmini arms. If anyone can point me in the right direction my right arm will love you for it.
Post Posted: Mon Mar 07, 2011 8:06 am
Bits4vits is where my camber bolts came from. I'd be surprised if the calmini struts had wider mounting points than stock so they would be fine.
Someone correct me on the cal struts if they know otherwise.
Post Posted: Mon Mar 07, 2011 8:24 am
camber bolts to suit a Vitara will fit any strut, not sure about the caster bushes fitting the Calmini control arms... as a guess I would say no.
Online
Post Posted: Mon Mar 07, 2011 10:00 am
What makes You sure its a caster problem?
Could be the infamous idler arm/bush issue?
If it is a caster problem caused by a big lift, search "hagen widening mod"
for a possible solution
Post Posted: Tue Mar 08, 2011 4:51 am
Yeah Atari your right bits4vits bushes won't fit the calmini arms.
Christover1 i had a wheel alignment done and they gave me the print out showing its out left is +1.33 and right is +2.20. I did have a look at the idler arm just to be safe nothing is bent, got the missus to move the steering wheel left and right and i couldn't see any play in the bushing.
I think i will have to find a place to make up some offset bushes for the calmini arms.
Online
Post Posted: Tue Mar 08, 2011 4:54 am
Hopefully there is something off the shelf from some other fitment..
Post Posted: Tue Mar 08, 2011 4:56 am
is that camber or castor?
Post Posted: Tue Mar 08, 2011 5:18 am
Caster
Post Posted: Tue Mar 08, 2011 5:22 am
for that much different I would be looking for whats bent first, thats a fair difference
otherwise a 'dodgy' person might slot the left hand rear mount outwards a bit until the castor was correct and weld soem washers in place to fix it in place and correct the castor
Post Posted: Tue Mar 08, 2011 8:08 am
i think the cross member has been pushed to the right but shouldn't it be very noticeable to make nearly 1 deg difference and it didn't pull to left before i put the lift kit in unless the lift exaggerated problem.
Post Posted: Tue Mar 08, 2011 9:06 am
does it drive straight if you sit in the right lane of a multilane road? IE so the road is cambering to the right not the left?
Post Posted: Tue Mar 08, 2011 9:36 am
Nah its pretty bad, the 12 o'clock position on the steering wheel on a straight flat road sits at about the 2 o'clock position, no matter what road I'm on I'm always pulling the steering wheel to the right.
Do you think i could use 14mm camber bolts to replace the control arm rear bolts? I just don't know about the length of the camber bolts, standard bolts are 90mm from under the bolt head to end of the thread .
Post Posted: Tue Mar 08, 2011 9:41 am
do you know what your camber is? I've found shitty camber accounts for more weird shit than castor
I think youd be better of trying to find some eccentric bolts out of some other car with similar bush dimensions
Post Posted: Tue Mar 08, 2011 9:54 am
Sorry that's what meant to say :oops:
Post Posted: Mon Mar 14, 2011 8:18 am
Well i fixed the caster issue, i used Royce's 'dodgy person' idea and slotted the rear holes, it was that bad the bolt holes had to be moved 8mm to the left but it now tracks correctly. Thanks everyone for your assistance. Here's some photos excuse the welds :oops:
Post Posted: Wed May 14, 2014 10:54 pm
Hey all, i know this is a bit of a grave dig but searches will do that. Had a wheel alignment today as i was getting bad wear on my new tyres:( it pulls to the left rather bad. Camber and toe are good, but caster is bad LH IS -0.03deg and right is +1.4. I have a straight heavy duty idler arm brace.
What should i be looking for? Worn bushes in front control arms? Busted strut mount bush?
Thanks
Mitch
Post Posted: Wed May 14, 2014 11:18 pm
Caster is the front~back tilt of the "king-pin" - since you have macpherson strut suspension there is no "king-pin" perse, so you're looking at an imaginary line drawn from the strut mount at the top to the ball-joint at the bottom - the points around which the wheel pivots.
Anything that moves one of these points in a front~back direction will cause the caster to change, anything that moves them sideways will cause the camber to change.
I find it strange that camber would be good & caster out - but - if that's what you got I would be looking for a bent control arm.
Post Posted: Thu May 15, 2014 4:16 am
Yeah i understand the concepts, ture shop pretty much said every bush in the front end causes caster issue! Which im not that retarted. So flogged out control bushes wouldnt cause it?
Post Posted: Thu May 15, 2014 5:27 am
Tiny amounts yes
Check ur towers
One could be bent back
Post Posted: Thu May 15, 2014 12:04 pm
If the bushes are shot they will affect both caster & camber - which is why I find it strange that camber is good but caster is not.
Post Posted: Thu May 15, 2014 4:57 pm
Ok ill check the towers, i got camber bolts in so they prob adjuted them to fix the issue. Or would it be way out still?
Post Posted: Mon May 19, 2014 4:06 pm
Well checked the towers, couldnt really fault them. Its only 2 deg between the left and right, should i be able to see that? I compared both sides without a difference seen.
Can someone measure between the two front arm mount bolts? Pls (center of bolt to Center of bolt).
Thanks
Online
Post Posted: Mon May 19, 2014 4:43 pm
I get 450mm but it is dark, so not dead accurate.
Post Posted: Mon May 19, 2014 8:10 pm
Ok thanks chris, how do u find the castor correction bushes? Did u take both arms completely off to fit them?
Online
Post Posted: Mon May 19, 2014 8:24 pm
Mine seems to handle much better with them.
Hardest part was removing the old bushes.
I did it with the arms off, as my bushes needed a lot of aggression to remove.
If Your bushes easily remove, then on car could be done.
Post Posted: Tue May 20, 2014 4:42 am
Ok thanks, how long did it take you all up?
Mine is 43.8cm.
Thanks
Online
Post Posted: Tue May 20, 2014 7:43 am
Was all done in a day.
So allow half a day for a fit bloke with good tools.
Users browsing this forum: No registered users and 523 guests
