It is currently Sat Sep 26, 2026 11:04 am
Vehicle: sj40
Post Posted: Fri May 16, 2014 8:27 pm
Hello All
I have a valve /rocker noise that has me beat. I have adjusted the rockers as per specs and even less than the specs but the noise is still there.
I have replaced the valve stem seals and was wondering if I could have fitted the rocker shaft the wrong way around or if the guides could cause the tapping sound.
Any help on this would be appreciated
Thanks
Post Posted: Sun May 18, 2014 5:18 pm
Can you pin point the noise? How does the cam and rocker rollers look?
Vehicle: sj40
Post Posted: Sun May 18, 2014 6:32 pm
They look ok from what I can tell. Should I be looking for something in particular
Post Posted: Sun May 18, 2014 8:46 pm
Im not sure if happens on the small motors but check for macrospalling and galling or breaking up of the hardened surface.
Look for any rough surface on the metal to metal contact point on the cam.
Could be a injector but hard to say without hearing it. How long has it been doing it for?
Vehicle: sj40
Post Posted: Sun May 18, 2014 9:03 pm
It was doing it before I pulled it down and changed the head gasket I thought they just needed to be adjusted .The big problem is I cant run it with no rocker cover as it throws to much oil everywhere. Its a 1 litre F10A sorry I forgot to mention that.
Post Posted: Sun May 18, 2014 9:28 pm
Ok, was there any sign of valve or piston damage? I havent worked on or even seen a f10a so cant be precise. Someone else should be able to chime in with more help
Vehicle: 1992 suzuki vitara
Post Posted: Sun Jul 13, 2014 9:18 am
Try running some 98 in her fixed my valve noise issue
Cheers Joel!!
Vehicle: 84 sj41
Post Posted: Wed Sep 16, 2015 11:23 am
Hi I am trying to change my valve stem seals do I have to remove do I have to remove the rocker shaft to change them I have an f10 a
Users browsing this forum: No registered users and 26 guests
