Trying to fit a new serpentine belt to a 2000 2.0 Grand Vitara. Got a 5pk1645 old belt (hard to read) looks like 5pk 1650 ?? Cant get the new belt on, looks way too small even with the spring loaded tensioner at full adjust. Cant quite see the alternator to see if I can back off the adjustment to give me a bit more slack. Looks like it might be hard bolted. Any ideas??
1) There is a difference in the belt lengths - you can see it in the numbers 2) It's obvious that gregwatkins has a 2.5 V6 GV and probably did not notice the question specifies a 2.0 - the belts tensioners are different.
Users browsing this forum: No registered users and 162 guests
