It is currently Tue Aug 04, 2026 12:25 pm
Vehicle: Sierra
Post Posted: Wed May 21, 2014 12:34 pm
Got a new fuel pump yesterday from Autopro and it doesnt seem to work. When it is bolted up and he car is turning over it doesnt seem to seal against the head and it spews out oil from the bottom. I tried 2 different gaskets and they both do the same. Upon looking at the pump they are a little bit different (Photo attatched) looking for suggestions on what to do?
Thanks
Post Posted: Wed May 21, 2014 2:40 pm
Did you put the little plastic spacer back in too? All surfaces cleaned before reassembly?
Vehicle: Sierra
Post Posted: Wed May 21, 2014 2:42 pm
Yes i put it in but only tried 1 way. Is the spacer ment to sit against the head and the gasket against the pump, or the spacer against the pump and the gasket against the head?
Vehicle: Sierra
Post Posted: Wed May 21, 2014 2:55 pm
Not sure if you would really call it a spacer? It is just like a plastic gasket?
Post Posted: Wed May 21, 2014 6:33 pm
I believe the purpose of the spacer is as a heat insulator. It helps to stop the fuel getting heated unneccesarily.
Post Posted: Wed May 21, 2014 9:42 pm
Did you out the gasket on both sides of the black thing??
Post Posted: Thu May 22, 2014 7:31 am
New pump could have a stronger spring. Make sure you do up nuts evenly, so it don't jam, and do up to spec.
Vehicle: Sierra
Post Posted: Thu May 22, 2014 10:10 am
Only came with 1 gasket. I have a new pump coming today from 4wdproducts off ebay, I have used him before for other stuff so i sure it will be right. It comes with 2 gaskets.
I have done some research and it looks like I need to put a gasket on both side of the black spacer? Is that right
Post Posted: Thu May 22, 2014 12:25 pm
Yes, should have gasket on both sides of plastic insulator/spacer
Users browsing this forum: No registered users and 80 guests
