It is currently Tue Aug 04, 2026 6:28 pm
Vehicle: Sierra
Post Posted: Sat May 24, 2014 7:04 pm
Looking for some tips on the easiest way to remove a sierra fuel tank, and also best way to clean the pickup?
Gonna fix a few dents while it's out aswell
Vehicle: sj51
Post Posted: Sat May 24, 2014 7:15 pm
How ive done it in the past
Empty it first,
put trolly jack under the middle,
undo filler hose,
undo mounting bolts,
partally lower,
chock it so it dosent fall off the jack,
undo fuel hoses and sender wire,
fully lower jack,
drag out from under car
Vehicle: 93 Sierra
Post Posted: Tue May 27, 2014 5:02 am
Dents don't tend to like being 'fixed' ... I had the ridge between two dents crack and start leaking on a long trip when I was 2500km away from a major city, which really isn't ideal. You can likely pick up an undented tank for around $80 ... that'd be my recommendation, and is what I did for mine.
As for the removal - pezz is on the money. There's really not to much to it though once you get under there. Just undo the filler hose, support it temporarily, undo 4x bolts, drop it slightly, remove all hoses and wires and drop it out. Refitting is the reverse but with more swearing and scraped knuckles :lol:
Vehicle: LWB Sierra & XL7
Post Posted: Tue May 27, 2014 7:31 am
^^ just drive around until you think the fuel is gone.
Couple bolts and clamps, it's pain in the arse job but easy.
'92 Vitara & Camper trailer
Post Posted: Tue May 27, 2014 1:19 pm
I find the bash and solder up the cracks method quite effective 8)
Users browsing this forum: No registered users and 73 guests
