It is currently Thu Oct 15, 2026 3:27 am
Vehicle: LJ81
Post Posted: Wed May 28, 2014 12:01 pm
Anyone know the best way to pull the vinal covered plyboard inner door trim off? Have got everything unbolted except the window winder handle and am looking for the best way to remove it without damaging it? Thanks mick
Vehicle: 1997 Sierra SJ80
Post Posted: Wed May 28, 2014 2:26 pm
Should they not be held on by door clips?
A flat blade between metal and plyboard, and gently prise.
2 scrapers, one each side of the clip, for added safety
Post Posted: Wed May 28, 2014 2:32 pm
Just re-read. Window winder as well?
From memory, it has a little pin that just pushes out when you lever the soft plastic surround back.
Or do they use the circlip? been so long..
Post Posted: Wed May 28, 2014 10:10 pm
Yep, little pin. You fold the rubber surround thingy back and push the pin out, then the handle slides off. Mark which way it went on so you get it in the right spot again. :)
Vehicle: LJ81
Post Posted: Thu May 29, 2014 11:42 am
Gotit off in about thirty seconds thanksguys
Users browsing this forum: No registered users and 1066 guests
