It is currently Mon Oct 26, 2026 9:35 pm
Vehicle: Sierra SJ50
Post Posted: Fri May 30, 2014 7:39 pm
Hey guys,
Looking to put some rear
Springs in the front of my zook, wide
Track sj50
Whats the easiest way to do it?
How hard is it to do it without any sort of kit?
What is involved
Post Posted: Fri May 30, 2014 7:44 pm
search.php
Vehicle: sj51
Post Posted: Fri May 30, 2014 7:45 pm
Sj50 should be a narrow track
Vehicle: 90 hardtop and 89 soft top
Post Posted: Fri May 30, 2014 7:58 pm
My Sj50 is wt
Vehicle: sj51
Post Posted: Fri May 30, 2014 8:01 pm
Hmm, my sj51 is narrow, I always thought it was just sj70s that were wt... lernt something today :)
Post Posted: Fri May 30, 2014 10:44 pm
yelozuki wrote:
My Sj50 is wt
If you want us to spend time providing you with information how about you start by providing us with some. You say your car is an sj50 WT, is it the yellow one in your avatar?, what year is it?, is it a NT with WT diffs?, does it have a WT or NT chassis? Can you take some pics of the front of the chassis where the shackles mount.
Vehicle: WT sierra, GU CRD
Post Posted: Fri May 30, 2014 11:10 pm
My SJ50 is WT, and I'm pretty sure my mates WT is SJ50 also.
Also two stroker, Yelozuki isn't the OP.
Edit: unless he has multiple accounts.
I love ZD30. :)
Post Posted: Sat May 31, 2014 1:54 am
SJ50 was the NT 1.3 AND ALSO the first WT. Had plastic flares and 3.9 diffs.
Post Posted: Sat May 31, 2014 2:22 am
carn guy's it's not that hard to throw a few links up for light reading & to give him 1/2 an idea what he's up against. :beer:
here's a few i found.
viewtopic.php?f=17&t=18955
viewtopic.php?f=17&t=2174
Post Posted: Sat May 31, 2014 2:27 pm
There are so many sierras around that have been re bodied, re chassis'd, WT/NT conversion etc etc etc. so for anyone to help him out I don't think it is unreasonableness that he answer some basic questions. Anyone that has done a few RUF knows it is a different process to RUF a WT compared to a NT.
Post Posted: Sat May 31, 2014 2:42 pm
fair enough, surely there are threads for both though, the sj codes are all over the shot & confuse me a fair bit.
pretty sure ajsr's bbq'd barge was a wt, that was nt spring spacing & ruf'd.
Post Posted: Sat May 31, 2014 3:18 pm
You've changed....
Post Posted: Sat May 31, 2014 4:07 pm
shhhhhh, it's just a front. :thefinger:
Post Posted: Sat May 31, 2014 4:32 pm
thanks atari, found some useful info in them
getting the pics from my phone and ill post in a sec for 2stroker
Post Posted: Sat May 31, 2014 5:44 pm
i always assumed if the mounts were offset to the chassis it was wide track
Post Posted: Sat May 31, 2014 6:14 pm
WT :beer:
Post Posted: Sat May 31, 2014 6:33 pm
thanks for the reply
Post Posted: Sat May 31, 2014 7:53 pm
Thanks mate, yep WT which is always a but more work and a bit harder to disguise
Post Posted: Sun Jun 01, 2014 12:11 am
For a silver WT chassis it should end up something like this:
Dan
Post Posted: Sun Jun 01, 2014 8:12 am
2stroker wrote:
yelozuki wrote:
My Sj50 is wt
I have 2 sierras my yellow one is a sj70 and I have a white one that's a Sj50.
Diffs look the same to me and I'm certain neither has been body swapped.
Post Posted: Sun Jun 01, 2014 9:51 am
Factory sj50 WT plus I have owned a total 4 WT sj50s.
I suspect that QLD is a bit different due to having a different importer then the rest of Aust.
Post Posted: Sun Jun 01, 2014 11:07 pm
Dan
yeah, i looked through that thread and that's what ill be following when i get everything and start the conversion, hopefully comes up alright
Post Posted: Mon Jun 02, 2014 4:04 am
Just read through it carefully and add some more length to your hanger spacing if you are going to use EFS length springs (I had to find that out the hard way) or use slightly shorter springs.
Vehicle: Vit swb 95
Post Posted: Thu Jun 05, 2014 10:22 am
I have a SJ51 and i can confirm its a NT.
Also looking at doing the RUF. But i need to go through rego before the moding begins.
Post Posted: Thu Jun 05, 2014 6:42 pm
SJ51 are all NT lwb/ute.
SJ50 is both NT & WT Swb.
Users browsing this forum: No registered users and 328 guests
