It is currently Sun Nov 01, 2026 3:12 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2
Vehicle: Suzuki Jimny
Post Posted: Sat May 24, 2014 12:28 am
Hi guys, can you please tell me where can I buy the 73821-76J20-5PK fascia for a suzuki jimny 2014? Actually I have the 73821-76J00-5PK fascia but this one doesn't work (fit) for a GPS radio that I have bought.
So, please help me, I don't know where I can buy this fascia (73821-76J20-5PK).
I'm sending the link of this radio:
http://www.aliexpress.com/item/Car-Head ... 43949.html
Post Posted: Sat May 24, 2014 12:34 am
Mike57 wrote:
Thanks for your help, but I need the 73821-76J20-5PK fascia, do you know where can I buy it?
Vehicle: Suzuki Jimny 2009
Post Posted: Sat May 24, 2014 1:18 pm
You should be able to source any part through the Amayama web site. You give them the part number that you want and then they email you to confirm that they can source it and give you a price. It actually works well. Did you try them?
Vehicle: 2009 Jimny
Post Posted: Sun May 25, 2014 7:34 pm
Just found the part no for the original 2 to 1 DIN conversion kit.
99KIT-81A00-CS1
Post Posted: Tue Jun 03, 2014 11:50 pm
Hi Mike, this is the Anamaya reply about my request:
Hello,
The requested part is out of stock with an unknown delivery date. We
cannot supply it at this time, nor can we estimate when it will become
available.
Regards,
George
So, I don't know where I can get this fascia (73821-76J20-5PK).
Post Posted: Tue Jun 03, 2014 11:56 pm
wacky_will89 wrote:
G'day all,
We all know how pathetic the standard stereo system is in the Jimny. So in desperation of having a stereo i could actually hear and use I set out to replace it. After some searching on this and various other forums I found a lot of people had suggestions on what audio gear to use but not a clear how-to.
Keep in mind this is not necessarily a sound system i would recommend but not bad when working on a budget. I also wanted to go for the cleanest finish with minimal cutting drilling or bending.
I started with the front speakers. Removing the kick panels was very easy. Just a matter of removing the door sill guard and then the trim clip in the kick panel and it pulls away.
Kick panel.
To my horror these were the speakers i discovered and removed.
The standard speaker holes will accept a 4" speaker with no problem. They may accept a 5" speaker but i could not find one that would fit without either using a spacer or modifying the mount holes. I replaced them with a pair of Jaycar Response Precision 4" kevlar speakers.
While i was replacing the front speakers I also decided to fit a pair of the same 4" to the rear. (I will post a how-to on rear if requested but i did find one on another forum.)
With the four new speakers the sound system was starting to sound a lot better. This new setup didn't last long though as the limited functionality and power of the stock head unit was annoying me.
Here in lied a huge problem as it seemed no one made a fascia kit for the Jimny. I didn't want to spend upwards of $400 on a cheap looking ebay brand head unit just to maintain a clean look. Besides I already had a perfectly good bluetooth Pioneer 1 DIN head unit which would leave me space to fit a UHF in dash and not have to make up a mounting system for elsewhere. I did come across the topic from 'cammac' which showed that the fascia kit from 'AudioExpress'. I took the Suzuki part number from the supplied Audio Express kit to my Suzuki dealer and, sure enough, I had a genuine Suzuki fascia kit in my hands within a few hours. It only cost me $103.
So i set out removing the old head unit.
Just pull it off. There are 6 clips, three on each side. The silver edging is screwed on from the back and it comes away with the main piece.
Lighter socket plug.
Hazard Light plug.
The trimless dash.
I removed the Silver edge pieces that are held on by a few screws each side.
The lighter socket is tricky to remove.
you have to push this black tab while trying to slide the metal part towards you.
Once the metal socket is out the plastic retainer is removed by pushing in the plastic clips on each side while removing it.
Back of the hazard switch which is removed by pushing the top and bottom tabs and feeding it through the panel.
The airvents also push out with a bit of encouragement.
The two fascias. Replacement on the left.
Then transfer the stuff from the old fascia to the new one.
The next step is to change the head unit which i don't have photos for yet but i will try and put some up soon.
The cradle that holds the head unit slides out after removing the four screws that retain it. Then unclip the harness and antenna.
For the vehicle to ISO harness i found the Aerpro APP071 suited my Jimny standard wiring. To fill in the spare space below my 1 DIN head unit i used a universal 1 DIN pocket i had lying around at home.
Here is the result once wired up tested and installed.
The sound is a lot better than the factory sound. Obviously it is not a high end audio system. Though, without spending huge money on an amp, nicer speakers and a sub, i have still managed to get a lot better sound system.
With a bit of previous experience in fitting car audio this was pretty easy and took me less than a day to complete.
Let me know if this was helpful or if you need more info on any part.
Hello wacky_will89, I'm trying to find where to buy the Suzuki Jimny Fascia 73821-76J20-5PK, Do you have to sell? I don't mind if it is a used one.
Post Posted: Thu Jun 05, 2014 10:23 pm
Hello,
available.
Regards,
George
OK. The other place I could have got one from was a Suzuki dealer in Brisbane but it was cheaper through Anamaya at the time. Have you tried any of the dealers in Brisbane?
Post Posted: Fri Jun 06, 2014 4:59 pm
The 73821-76J20-5PK version is the stock fascia that came on all Australian Jimnys. They pop up on eBay occasionally or you could post in the wanted section on here if you are willing to buy a second hand one.
Vehicle: Jimny & Grand Vitara
Post Posted: Sat Jun 21, 2014 11:39 am
ccorrea,
My Jimny came standard with the 73821-76J20-5PK fascia... And I would like to replace it with the 73821-76J00-5PK...
Do you want to trade?
Rafael
Brazil
Vehicle: 2013 JImny
Post Posted: Wed Jul 16, 2014 11:35 pm
Part No. 990E0-59J55-000 single din and pocket conversion.suzuki part number
http://www.suzuki-motor.by/assets/files/aksessuary/jimny.pdf interior section of brochure (pic)
73821-76J10-5PK
http://suzuki.automeistras.lt/wp-content/uploads/2014/05/Katalog_Jimny.pdf
audio and navigation sectionFor cars with serial radio:
Mounting frame: Part No. 73821-76J10-5PK (1x) width 184mm
Vehicle: Suzuki Jimny 2010
Post Posted: Thu Jul 17, 2014 6:38 pm
Does anyone have a double din fascia of any model number they no longer require? I'm looking at doing a bit of a secret mod and need one I can cut up.... I'm happy to pay postage etc and a small fee for the fascia as well
Vehicle: 91 Tin Top
Post Posted: Thu Jul 17, 2014 6:48 pm
More secrete mods... Armsup
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Jul 17, 2014 9:26 pm
insert picture of jimny front seats here
Post Posted: Wed Apr 19, 2017 10:34 am
Anyone got the 2DIN dimensions for 73821-76J10-5PK - Double DIN please? I too need 178*100 for an Android unit in my 2010 Jimny.
Anyone used the small infill (in either size) with the standard dash 73821-76J20-5PK? See here -
http://www.ebay.com.au/itm/Double-Din-R ... 1116551983
Appears 73821-76J00-5PK - Double DIN is "175mm wide by 102 mm high, give or take a mm" (Mike57).
'10 Jimny, M18A, 80mm lift kit, 215/75R15 on ROH mags, rear disk brake conversion and front disk vented upgrades. Air Lockers front and rear; cruise control; 70L fuel tank. Castor corrected Radius Arms, rear panhard rod raised mount, steering damper; bash plates transfer, radius arm, shocks, dual batts, headers, winch, rock sliders, custom aluminium roof rack on fitted tracks, Atoto head unit, LED headlts & HID 7" driving lights; 105Amp alternator to feed all the lights.
Vehicle: G16b Sj80, Version 6 GC8 STi
Post Posted: Wed Apr 19, 2017 11:24 pm
https://aerpro.com/vehicles/suzuki/suzuki_jimny_2005
Subi + Suzi = Best of both worlds!
Users browsing this forum: Google [Bot] and 267 guests
