It is currently Tue Jul 28, 2026 9:40 am
Post Posted: Tue Jun 10, 2014 7:26 pm
Looking for transfer gears for my 04 GV but the kits say they only fit up to 02. Are there any differences in the t case gears after 02 or is it just cal covering their ass again like their suspension kits? Or does any one know any gears to fit the GV t case?
Kit in question
http://www.calmini.com/detail.php?b=2&m=7&t=3&p=759&n=
Post Posted: Tue Jun 10, 2014 7:44 pm
Not sure if calmini are the same but I was told by trail gear that their reduction gears are only to suit the 4 cylinders not the v6. This doesn't necessarily mean that the transfers are any different, just that they haven't looked yet.
I think in the US they had the vitara right through to 2002 along side the GV, but they are different vehicles. I have a transfer from each and will be pulling them down to see if they are the same or if they can be adapted. I believe that the manual and auto transfers are different in the GV
Post Posted: Tue Jun 10, 2014 7:52 pm
Yea cal say in the description that they fit the gvs so not sure on that. Do you have an 04 GV case of just an early vit and early gv to compare. The ktis fit in both man and auto so it must be a universal gear set to reduce the input shaft or something i have no idea.
Post Posted: Tue Jun 10, 2014 8:10 pm
Early GV and vit. No idea on the later models.
I've sent them an email, will reply here if I get a response.
Post Posted: Wed Jun 11, 2014 5:56 am
Calmini replied and said it will not suit a V6 transfer
Post Posted: Wed Jun 11, 2014 9:50 am
Wow so no chance for the big gvs. Bummer. Any one working on a set for them?
Post Posted: Wed Jun 11, 2014 10:06 am
I searched for it but couldn't find any reference to anyone fitting transfer gears in them which is why I thought I'd try to adapt the vit transfer. I've read now that even the manuals are very different so that may not be possible either
Post Posted: Wed Jun 11, 2014 10:27 am
Bugga I can't be bothered trying to screw around with a new t case so ill have to wait for someone to come up with something. But for you a vit case should work.
Post Posted: Wed Jun 11, 2014 10:42 am
If you're pulling out your transfer to put gears in it it's just as easy to adapt up another one as it is to put yours back in if there is a kit for it. Just means you have a couple more bits to source.
Post Posted: Wed Jun 11, 2014 11:02 am
Rikstr was selling a set of custom gears for a XL7 a while back not sure if they will fit or even if he still has them but it's worth a look
Post Posted: Wed Jun 11, 2014 11:05 am
I don't really want a whole nother transfer to deal with and pay for. Thanks ill ask him about it!
Post Posted: Wed Jun 11, 2014 11:40 am
Fair enough. Link is here:
viewtopic.php?f=7&t=40644&p=754585#p754585
If the shaft was resplined that means that the XL-7 box had a larger output than the vitara one by the sounds of it. Meaning resplining or a custom output shaft would be required.
Vehicle: 99 Grand Vitara
Post Posted: Wed Jun 11, 2014 12:29 pm
Wonder how the xl7 transfers differ to gv's. Mines auto so may fit :)
http://www.strictly4x4.com.au
Post Posted: Wed Jun 11, 2014 2:55 pm
Auto should fit a vit tc but manual have different output spline I read on Zuki world.
A xl7 on 37 ran vit tc gears .
Post Posted: Wed Jun 11, 2014 3:14 pm
i've read that before, auto gv's only was my understanding & i'm certain the SV620 manual is a fair bit shorter than the SQ, not sure about the gearboxes in the SQ420 though?
Post Posted: Wed Jun 11, 2014 4:22 pm
I had a few t/cases here when I blew mine up
Mines a V6 manual and they gave me a V6 Auto one and there was a difference in the length of the input shaft.
As for ratio's the Man and Auto were the same high and low. Well the 2 cases I had were as I counted the turns in and out.
SE Vit t/case was different again. had a different spline.
Vehicle: 99 suzuki grand vitara
Post Posted: Fri Jun 13, 2014 7:49 pm
Really keen to see what differences you found with the vit and g/vit transfers Zook-Fan
Post Posted: Tue Jun 17, 2014 1:45 pm
Hey all, any insights your collective experience could provide here would be much appreciated: viewtopic.php?f=5&t=46656
Users browsing this forum: Google [Bot], ProteinDrinker and 397 guests
