It is currently Sun Aug 02, 2026 3:21 am
Vehicle: 98 Jimny
Post Posted: Tue Jun 24, 2014 11:03 pm
Hi, I have just recently finished my ORA W/T Transfer case conversion in to my 98 jimny and my speedo has stopped working it was working perfect before conversion but now it wont move at all, has anyone else had this problem or do you know how to fix this problem??
Thanks
Michael
Vehicle: Suzuki Jimny 2010
Post Posted: Wed Jun 25, 2014 4:24 pm
Didn't forget to plug the sensor back in??? Or blow a fuse?
The speedo wire is green from behind the dash. If you undo the 4? Screws holding the cluster in, it'll pop straight out and you should be able to test light/multimeter it.
Vehicle: 98 Jimny
Post Posted: Wed Jun 25, 2014 4:33 pm
I plugged the sensor back in definetly, do you have a picture of the fuse? Would help me alot. more of an visual person.
Post Posted: Wed Jun 25, 2014 4:35 pm
My jimny is half hour drive away bit I'm pretty sure there's a speedo fuse with the rest of them (ie radio, lights etc)
Does the tacho work?
Vehicle: 98 Jimny
Post Posted: Wed Jun 25, 2014 4:42 pm
Tacho? The rev side works. Just not the speedo:l
Post Posted: Wed Jun 25, 2014 4:46 pm
Lol that's the tacho.... If that's working then I'd suggest you look at the sensor and double check it's clean, the wire isn't broken, the pins in the plug haven't been bent or damaged. I'm not overly familiar with the ORA kit, but from what I know the sensor goes onto a bracket? You haven't got the sensor the wrong way round? (I don't know if that's possible or not?)
Post Posted: Wed Jun 25, 2014 5:10 pm
tried closing the gap between the sensor & the tone ring? it's probably spaced too far away to pick up a signal.
Vehicle: 98 Jimny
Post Posted: Wed Jun 25, 2014 5:24 pm
I left the little rubber ring on because it fits more snug on the mount, ill try taking it off to see if it can get closer thanks yous both ill try and find the fuse also bring the sensor closer.
Post Posted: Wed Jun 25, 2014 8:11 pm
Maybe share a photo of your speedo ring and sensor
Vehicle: 98 Jimny
Post Posted: Wed Jun 25, 2014 8:14 pm
Ill send a pic first thing tomorrow morning when it is light.
Vehicle: jimny g13bb, 99 wrx!
Post Posted: Sat Aug 02, 2014 2:48 pm
Any fix on this? I also have the same problem. Starting by first trying to test the sensor. Waiting on a multimeter at the moment. I tried to spin the output by hand and have the ignition on to see if the dial moved to confirm i would have to close the gap. No luck
Vehicle: 98 Jimny
Post Posted: Mon Aug 04, 2014 4:03 pm
sorry mate for the late reply but my sensor got hit by the flange bolts need to replace the whole thing
Users browsing this forum: Google [Bot] and 366 guests
