It is currently Tue Jul 21, 2026 10:17 pm
Vehicle: 1992 suzuki vitara
Post Posted: Tue Jul 08, 2014 10:58 am
I was a bit worried about the front diff on the vitara so I thought I'd make a bash plate. Wasn't really much on here about them so I copied my mates one and made my own version out of 5mm aluminium checker plate cost was $40.00 for material and 10$ for the cuts and bends. I drilled and taped holes up the front and used the existing holes I'm the gearbox crossmember I think 8mm ran a tap through it and bolted it up. Come up good I think Image
If anyone is having trouble making or buying one throw me a private message and I can help you out with measurements and bends. Also gonna make a transfer box bash plate soon so stay tuned!!!
Cheers Joel!!
Post Posted: Tue Jul 08, 2014 12:17 pm
looks good, will save destroying the engine crossmember if you get hung up on something, same with the gearbox crossmember. that's the one that usually gets hammered but at least it's removable.
personally i would have put the smooth side out but that's just me.
Post Posted: Tue Jul 08, 2014 2:33 pm
thanks mate!! i hope it does its job lol!! i didnt really want checker plate but it was an off cut so it was cheap
Post Posted: Thu Jul 10, 2014 4:01 pm
It's not checker on both sides though. Checkerplate is designed for grip. Skidplates should slide.
Vehicle: Suzuki Vitara X90 1996
Post Posted: Thu Jul 10, 2014 6:33 pm
Looks Good!
I'm thinking of doing the same thing.
Suzuki X90's Rule
BearX90
Post Posted: Thu Jul 10, 2014 9:00 pm
Yeah it's kinda just for looks the checker plate I don't really think it would stop it from sliding but thanks for your opinion
Cheers Joel!!
Post Posted: Thu Jul 10, 2014 9:02 pm
BearX90 wrote:
Looks Good!
Suzuki X90's Rule
BearX90
Thanks mate!! I will take the bash plate off and post some pictures and measurements
Go THE VITARA/X90
Cheers Joel!!
Post Posted: Mon Jul 14, 2014 5:28 pm
So I might aswell post it on here..
The bash plate is about
460mm
Buy about 630mm
It's all a rough measurements but these pictures should help you make a template to help you make your own
Front angle
Rear angle
If you want any more measurements / cut out just comment and ask
Cheers Joel!!
Post Posted: Mon Jul 14, 2014 5:35 pm
Cheers Joel!!
:lol: they call it treadplate for a reason & it's not because it's slippy.
Post Posted: Mon Jul 14, 2014 5:41 pm
Cheers Joel!!
Yeah true but I don't think it will matter to much but you right was 40$$ for some 5mm stuff so it was ok
Cheers Joel!!
Vehicle: Which one?
Post Posted: Mon Jul 14, 2014 5:51 pm
What grade was the treadplate? Sometimes they are quite soft as they are meant to be bent and shaped and and what not.
I know it was made of scrap, but if I were to make one from ally and had to pay for the metal I would pay an extra couple of bucks per KG and get some 5082 rather than 5005/5052 (or even 3003, in some cases).
Post Posted: Mon Jul 14, 2014 5:59 pm
Yeah I agree but I made it for the fun of it it does the job cheap enough to remake. But I'll make it out of 3 or 4 mm steel
Cheers Joel!!
Vehicle: Vitara '91 jlx softie
Post Posted: Mon Jul 14, 2014 9:03 pm
Good work Joel. So much better than nothing.
Post Posted: Tue Jul 15, 2014 5:12 am
Thanks jeff ?
Cheers Joel!!
Post Posted: Tue Jul 15, 2014 10:24 am
Thanks Joel
this helps a lot Thanks.
Suzuki X90's Rule!
BearX90
Post Posted: Tue Jul 15, 2014 10:59 am
BearX90 wrote:
Thanks Joel
Suzuki X90's Rule!
BearX90
Thanks mate if you want anymore measurements or better pictures I will be taking it off this afternoon
Cheers Joel!!
Post Posted: Tue Jul 15, 2014 11:09 am
No Thanks Joel
I have a pdf file of full plate like yours but I do not kown how to put it on the forum.
can any one tell me how to put a pdf file up form my computer to the forum?
Suzuki X90 Rule!
BearX90
Post Posted: Fri Jul 25, 2014 5:20 am
Ok guys I had a day off work yesterday so I don't a few things... Blacked out behind my bar now it looks better pictures later. Made a reverse light coming from my spare wheel carrier and also a couple of Brackets for my 127pc sca toolbox I got for $65 just jumps straight into the air or slider around so it's gotta stop.. Will have pictures up tonight also I have installed snorkel, was a bitch to fit and I an working on a t/c bash plate aswell as a tank guard will post pictures this afternoon after I change all oils underneath the car thanks guys
Cheers Joel!!
Vehicle: 1990 swb vitara
Post Posted: Fri Oct 03, 2014 11:51 pm
is that for a swb or lwb vitara?
Vehicle: 1996 Suzuki Vitara JX
Post Posted: Sat May 30, 2015 5:49 pm
What did you attach the front of the Skid plate to?
Users browsing this forum: No registered users and 24 guests
