| Author |
Message |
Shaneo
Vehicle: 88 swb vitara
 Posted: Mon Jul 14, 2014 8:44 pm |
Hi guys can anyone tell me how high I have to go on body lift to fit 31" under it. Do make a kit or buy one?
Cheers Shane
Pico42
Joined: Sun Nov 20, 2011 8:05 am Posts: 82 Location: Brisbane AU, Queenstown NZ
Vehicle: SWB Vitara
 Posted: Mon Jul 14, 2014 8:53 pm |
Are you doing a suspension lift as well?
I like the bits4vits body lifts.
Shaneo
 Posted: Mon Jul 14, 2014 8:58 pm |
I will be doing suspension lift I think it's 50mm lift.
atari4x4
 Posted: Mon Jul 14, 2014 9:00 pm |
Welcome to AZ  seeing you're new here I'd strongly suggest learning how to use this awesome feature search.phpit's like a personalised exploration dig through all the previous posts on pretty much any suzuki 4wd related topic including bodylifts. you can buy a good quality 2" bodylift from here. viewtopic.php?f=15&t=15518
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13008 Location: Melbourne
 Posted: Mon Jul 14, 2014 9:03 pm |
Suspension lift isn't relevant to fitting a tyre. Really, it isn't.
2" Body lift will clear 31's without an issue.
Shaneo
 Posted: Mon Jul 14, 2014 9:33 pm |
Thanks for the replies guys. Glad I found this forum I've seen some dodgee lifts to get 31" under them. I was told I would have to go 3" body lift to get the 31" under her. I was hoping to do 2" body 2" suspension and be able to fit 31" under her. What are your thoughts.
atari4x4
 Posted: Mon Jul 14, 2014 9:36 pm |
2" + 2" is the way most people do it, unless you want to keep it extra low & do a heap of cutting.
Shaneo
 Posted: Mon Jul 14, 2014 9:41 pm |
Not massively keen to do a heap of cutting. Has any of you guys weld your diff instead of air lockers?
Gwagensteve
 Posted: Mon Jul 14, 2014 9:47 pm |
Weld a diff but won't cut the guards? Those things don't compute.
Don't weld the diff. Vitaras break axles with welded diffs.
Remember when I said suspension lift doesn't fit tyres? Why is that impossible for everyone to understand?
Body lift clears tyres. suspension lift tunes ride and compression travel to suit your needs.
The ONLY reason to run suspension lift to help clear tyres is if you need to run bumpstop spacing.
A 2" suspension lift with 2" bumpstop spacing clears tyres the same as 2"suspepension+2"body without bumpstop spacing, except the car is 2" less obvious to the cops. Same as a car with 2" body lift and no suspension lift.
atari4x4
 Posted: Mon Jul 14, 2014 9:51 pm |
post a pic of your vit
Shaneo
 Posted: Mon Jul 14, 2014 9:56 pm |
I don't mind trimming the guards but don't want to hack the shit out of them if I can just lift it a little higher. The only reason I said weld the diff is because I have 2 spare rear diffs sitting here.
Shaneo
 Posted: Mon Jul 14, 2014 9:58 pm |
My vitara is nothing to look at lol she's seen plenty of bush in her time.
atari4x4
 Posted: Mon Jul 14, 2014 10:06 pm |
you should throw some pics up anyway, most of us can't read.
