It is currently Fri Oct 09, 2026 12:16 am
Vehicle: 30s front locker barwork
Post Posted: Tue Sep 01, 2009 12:46 am
hey guys
my engine is on its wat out in my seirra 1.3 i am wonderin should i rebuild the 1.3 biger n better with a bigger cam n stuff and does working the motor require a blue plate bcoz thats my problem because i am on my P's
Post Posted: Tue Sep 01, 2009 1:14 am
Shouldn't affect blue plates as it's not really changing anything. If you want to go down the re-building route it will cost dollars but probably worth it in my opinion, especially since you are on P's.
Post Posted: Tue Sep 01, 2009 10:03 pm
wat would be the best things to do to get a bit more power
Post Posted: Tue Sep 01, 2009 10:08 pm
Cam, carby & match port, extractors ! drive
Post Posted: Tue Sep 08, 2009 12:16 am
should i bore the engine n to wat size
Post Posted: Tue Sep 08, 2009 12:35 am
If you go the cam. Should you buy new rocker arms or can you use the origianal ones?
Post Posted: Tue Sep 08, 2009 1:14 am
If it was me in my eng, i`d have them refaced at the same place & time as the cam grind, but that just me.
If thay are not worn you can use them again, but is it worth the risk of a cam?
Steve
Post Posted: Tue Sep 08, 2009 11:09 am
Steve
x2. You might save a few dollars initially not doing the rocker arms as well as the cam, but you'll find the cam will probably chew out in time.
Post Posted: Tue Sep 08, 2009 12:56 pm
And "wat" is spelt WHAT. it is one push of a key, not that bloody hard....
Post Posted: Tue Sep 08, 2009 8:22 pm
i am geting the parts from lowrange offroad
who cares how it is spelt u still got wat i mean
Post Posted: Tue Sep 08, 2009 8:24 pm
OOOooooo!!!! :D
Post Posted: Tue Sep 08, 2009 9:31 pm
You have a keyboard. Don't be lazy please use it... we are not using "sms" now are we. If you do not have the time to use the 90 plus buttons on your computers keyboard, you do not really have the time to be on this forum do you.. :P
Post Posted: Tue Sep 08, 2009 9:33 pm
I`ve got spell check, don`t work on non grammar do .
Users browsing this forum: No registered users and 166 guests
