It is currently Sat Oct 17, 2026 11:54 am
Vehicle: 1991 Vitara SWB
Post Posted: Sun Jul 27, 2014 5:08 pm
Hey guys, I know the 31's will rub with only a 2" suspension lift but can someone tell me where?
Front or back? Outer guard or on the inside?
I'd like to grind whatever needs grinding before hitting the mud.
thanks
Vehicle: Which one?
Post Posted: Sun Jul 27, 2014 5:25 pm
Blah blah suspension lift isn't for tyre clearance blah blah
Post Posted: Sun Jul 27, 2014 6:29 pm
Yes, I realise that. A body lift would give more clearance for larger tyres but even a 2" BL requires some grinding or hammering according to the research I've done.
So with or without a BL, can anybody please answer my questions?
Post Posted: Sun Jul 27, 2014 6:41 pm
Back of the front wheel arches will be bad, I think you'd need to hammer the inner arch quite a bit and possibly adjust the accelerator pedal
rear of the rear arches, youll need to cut down the bumper, do something about the lip on the arch or fit really big bumpstop spacers and I think some of the bumper support gets in the way as well.
I think its doable if you dont go crazy with offset but youll be cutting a lot
Vehicle: SAS'd Vitara
Post Posted: Sun Jul 27, 2014 6:50 pm
40mm coil spacer lift only. 31s.
Some trimming on the rear of front wheel arch needed.
But tyre still slightly rubs on footwell on full lock.no big deal.
Post Posted: Sun Jul 27, 2014 7:21 pm
Thanks guys.
so less grinding / hammering if I put in some coil spacers??
Post Posted: Sun Jul 27, 2014 7:27 pm
No, less grinding/hammering if you put in bumpstop spacers.
Why is this the hardest thing in the world to understand?
Post Posted: Sun Jul 27, 2014 7:28 pm
What do you have?
2" lift already?
Post Posted: Sun Jul 27, 2014 7:29 pm
Because, 6" lifted wagon.
Post Posted: Mon Jul 28, 2014 9:11 am
That's what I said isn't it. 'Less' grinding with coil spacers.
Post Posted: Mon Jul 28, 2014 9:30 am
No, coil spacers will make zero difference to how much you have to grind. If the axle can reach the bumpstop- no change to how much grinding.
Vehicle: 2002 Suzuki XL7
Post Posted: Mon Jul 28, 2014 9:58 am
http://www.bits4vits.co.uk/store/vitara ... od_35.html
Post Posted: Mon Jul 28, 2014 10:17 am
Ok thanks. Thats a very clear explanation.
Post Posted: Mon Jul 28, 2014 10:18 am
Would you think I'm better off maybe just selling the 31's , and getting 30's or 29's?
Post Posted: Mon Jul 28, 2014 10:45 am
Just saw the bump stops. They look good.
Are there any negatives to them?
Post Posted: Mon Jul 28, 2014 12:18 pm
Reduced overall wheel travel by the thickness of the bumpstop spacer, however, on the rear the spacers allow you to fit shocks with twice the extra travel of the thickness of the spacer- so in the rear you can gain overall travel by fitting bumpstop spacers. In the front you'll loose travel because longer struts would make the cvs fall apart.
Post Posted: Mon Jul 28, 2014 2:21 pm
The chassy rail bellow is normally where it will first start scrubbing on anything above 29" with standard rims depending on tire width.
Vehicle: SJ80, SE416
Post Posted: Mon Jul 28, 2014 5:48 pm
^^^ my Vitara on 215/75r15 and standard rims rubs there...
Post Posted: Wed Oct 08, 2014 6:00 pm
31s, 2" BL and 40mm susp lift, steering stops adjusted, slight hammering/cutting of arch lips and tub.
Annoyingly few photos, sorry...
Users browsing this forum: Google [Bot] and 169 guests
