It is currently Tue Sep 15, 2026 7:27 am
Post new topic Reply to topic  [ 128 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Vehicle: vits
Post Posted: Wed Jul 30, 2014 12:35 am
monley wrote:
When are we going to see these lockers? I'm fuking sick of pos air leakers
2/3 air leakers I have had, leaked and the one that didn't was the one that wasn't fitted by ARB :roll:
What exactly do you mean as leaking monley? I used to work at a special vehicle company where all I did was fit the airines and wiring to ARB lockers, I installed literally hundreds.
As part of our testing we used to engage both lockers and waited to see how how long it took for the compressor to kick in for a top up of the air pressure, I can't remember exact figures now but I'm pretty sure 7 to 10 minutes was deemed as normal for a parked vehicle.
I worked there for a good 18 months, in that time we only had one fault and that turned out to be an incorrect install by the diff mechanic.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Jul 30, 2014 7:11 am
moneys had seals go and copper tubes get eaten by the ring gear im pretty sure
Vehicle: vits
Post Posted: Wed Jul 30, 2014 11:36 pm
The one fault we did have was the tube being munched, it was a bad install.
Threre isn't much room in the diff housing for the tube.
While I was working there I never heard of any problems with the seals.
Post Posted: Thu Jul 31, 2014 11:36 am
So you've mentioned that there are going to be more models, when are we realistically looking for the actual hardware to be available to public?
I have an airlocker I need installed in the next few months for a GV, will yours be available?
Vehicle: sj80 w/myside2. 99GV 2.5V6
Post Posted: Thu Jul 31, 2014 2:20 pm
Please tell, really would be fantastic if we could have a straight swap airlocker for the GV SQ625 98-05 without having the need to either chase down vit cv's or modify existing ones to fit.
Post Posted: Thu Jul 31, 2014 2:41 pm
you mean like machining the locker like stuey did?
Post Posted: Thu Jul 31, 2014 10:51 pm
My front locker shat its seals just recently... only been in there a year. The rear has never been an issue. I think it may be due to not being "used" and the seals lose lubrication or something... Mine only failed after a prolonged time of not using it... so i'm just making a point of engaging them once a week to keep it all moving around.
Post Posted: Thu Jul 31, 2014 11:25 pm
Yeah My rear sometimes works and sometimes leaks the front has never been a problem, So i also keep them engaged regularly to keep everything moving even though the manual said to engage them at least once a year...
Post Posted: Fri Aug 01, 2014 7:51 am
I mean one taht will be a straight fit into the front, one that allows for the 1/2 inch offset caused by the air actuator and lets the stock GV LHS half shaft and RHS drivers CV to fit.
ie pull diff, remove air centre, install air locker, reinstall diff, done
Vehicle: Suzuki
Post Posted: Sat Aug 02, 2014 10:46 am
I'd like one like that too for the alloy diff :P
Post Posted: Sat Aug 02, 2014 4:06 pm
That is the way it is :D
Post Posted: Sun Aug 10, 2014 11:16 am
It's like that and That's the way it is :D
Fixed it for ya :wink:
Post Posted: Fri Aug 22, 2014 4:02 pm
Introducing the CAP air operated locking differential.
After more than 10 years work on and off I am proud to finally be able to release an image of the CAP locker.
Why is it called the CAP locker? Because all it replaces is one bearing cap on your differential and uses the original side gears. It does not replace the whole unit. With many current model diffs having forged and webbed side gears why would you want to replace them? It also keeps the unit compact and affordable.
ALL components inside are replaceable. Damage a locking gear and there is no need to change the whole housing. Upgrading to larger splines? Simply change out one gear! There is only one moving part inside the CAP.
The housing is machined from solid and all components are heat treated. No possibility of a porous casting affecting strength.
The best part is if your vehicle has a factory LSD fitted......you get to keep it! This unit will bolt straight onto it giving you the LSD and the option of a fully locked differential.
The worlds simplest air operated locking diff. Designed in Australia.
Thank you to all who encouraged me over the years and helped with testing.
The images below show the complete rendered kit and an image taken from prototype fitting. Model shown is Vitara/Grand Vitara rear.
Vehicle: Which one?
Post Posted: Fri Aug 22, 2014 4:11 pm
Armsup
Post Posted: Fri Aug 22, 2014 4:13 pm
:) Armsup :peaceout:
Vehicle: 89 Sierra Widetrack
Post Posted: Fri Aug 22, 2014 4:43 pm
Good work!!
Post Posted: Fri Aug 22, 2014 4:46 pm
Awesome
How long till we can purchase a Vit rear?
Post Posted: Fri Aug 22, 2014 5:04 pm
Armsup Armsup
Happy days.
Vehicle: Sierra sj80
Post Posted: Fri Aug 22, 2014 5:34 pm
pompoms :beer: :peaceout:
Post Posted: Fri Aug 22, 2014 5:58 pm
Just wondering about what happens with the GV Front, as the moving side of the free-wheel clutch mechanism is at the other end of the centre therefore it is not eliminated by this design.
Post Posted: Sat Aug 23, 2014 8:22 am
That's not what it's designed to do. It's a locker, designed to work with the factory spec setup.
Post Posted: Sat Aug 23, 2014 8:35 pm
Maybe I'm a bit slow , but I cannot get my head around what voodoo magic this uses to make the diff locked.
Vehicle: sj51
Post Posted: Sat Aug 23, 2014 9:34 pm
It would apear it is locking one axle to the center, thus not allowing the spider gears to do there thing....... at a guess
Post Posted: Sat Aug 23, 2014 9:56 pm
So Joe, will you be machining up the rest of the centre so coily (and Jimny) guys can use this design in the front?
Vehicle: Sold zuk got a Bt50
Post Posted: Sun Aug 24, 2014 9:17 pm
Me like
Is there a web site we can look at. To see what other model cars this will be available for
bt50 now but still love the zooks
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Aug 25, 2014 6:10 am
Its suzuki only at the moment with testing still to be completed. plans for bigger easier diffs in the future
Post Posted: Mon Aug 25, 2014 7:06 am
Hmm, I believe it's not really the saviour all us GV guys were waiting for. One that gets rid of the air set up, I guess as most lockers completely replace the existing centre I was envisioning something along those lines.
as I'm also interested in the coily can someone shed some light on why an entire centre is required I have not opened one yet
Post Posted: Mon Aug 25, 2014 11:21 am
do what every other GV owner has done & run a vitara carrier.
Post Posted: Mon Aug 25, 2014 11:29 am
Cvs are the issue, as in hard to find. Worried about spares etc. I have a full vit centre here ready to go
Post Posted: Mon Aug 25, 2014 1:20 pm
as i mentioned earlier... machine the side gear as per ARB/joeblow & there isn't an issue.
Users browsing this forum: No registered users and 18 guests
