It is currently Sun Aug 02, 2026 1:45 am
Vehicle: suzuki sierra lwb
Post Posted: Mon Aug 04, 2014 8:50 am
Just wondering where you temp gauge needle sits in the gauge ..... also what is the right temp thermostat to be running in a standard sierra?
Im suspicious that my engine is running too cold .my temp gauge sits on about 1/4 .
Post Posted: Mon Aug 04, 2014 9:14 am
Should be just under half. Does it fluctuate when on highway and around town?
Pretty sure they run an 88 degree thermostat?
Post Posted: Mon Aug 04, 2014 3:47 pm
Sounds like you have the wrong thermostat , I only say this as mine was broken and at the time the closest I could get was 84 I think? And it did exactly as you say.
I have no idea of this is bad for the engine or just a little less efficient.
But for me was better than over heating all the time.
Obviously I have since fixed it.
Vehicle: 1991 swb vitara JLX
Post Posted: Mon Aug 04, 2014 7:48 pm
problem might be your gauge..just cause it reads quarter ..dont mean its that cold..i would try a 2nd temp gauge and see what temp it really is..just a cheap one from a auto spares shop should do it,,,,BUT as someone else has said .. least its not running hot
Post Posted: Mon Aug 04, 2014 7:57 pm
hi OBJ :hey:
Post Posted: Mon Aug 04, 2014 9:13 pm
Yeah as stated it running on 1/4 ... this is around town on the highway and when 4wding .im trying to fix a pcv problem (white grey foam ) .ive cleaned out pcv but also found a split in the main hose that runs from rocker cover to the air filter but there is still a small amount of foam being produced so tomorrow im fitting a new pcv and a new hose but I might as well put in a new thermostat while im there .ie engine running cool so not heating up properly therefore producing or colecting condensation.
Users browsing this forum: No registered users and 599 guests
