| Author |
Message |
1992suzukivitara
Vehicle: 1992 suzuki vitara
 Posted: Tue Aug 05, 2014 3:10 pm |
thinking of making up a few bash plates like this one for vitara's only  this is 5mm alu stands up good has bent but does the job what thickness steel or alu would you guys want ? just need something to do after work i enjoyed making one so i wanna make more
henno
Joined: Tue Jul 23, 2013 5:56 pm Posts: 2439 Location: Brisbane
Vehicle: Which one?
 Posted: Tue Aug 05, 2014 3:15 pm |
Not treadplate, for starters.
1992suzukivitara
 Posted: Tue Aug 05, 2014 5:26 pm |
henno wrote: Not treadplate, for starters. Yeah... Didn't effect it at any time but I was thinking 3 to 4 mm steel non checker plate
1992suzukivitara
 Posted: Tue Aug 05, 2014 5:38 pm |
Plus..think about it a little 1 mm price of aluminium is gonna stop over a 1 Tonne car from sliding over a rock or in mud or dirt I don't really think so but maybe steel but it's all I had it's worked great haven't gotten stuck up on anything on the bash plate.
henno
Vehicle: Which one?
 Posted: Tue Aug 05, 2014 5:43 pm |
So why don't you make it out of mesh then? Or coat it in sandpaper? You want it to slide, not grip, and yes physics dictates that little 1mm piece of aluminium could theoretically be the difference between sliding off or getting hung up on a rock.
I'm not trying to be a dick, just saying that the price of treadplate is usually more anyway... and if it was free, I'd fold it the other way so the tread was on the back. It's not like it's more cost nor is it more effort to not use a "grippy" surface, so I have no idea why you we are even questioning why you wouldn't use treadplate?
1992suzukivitara
 Posted: Tue Aug 05, 2014 5:57 pm |
Yeah I know what your saying and I agree just what I had at the point but thanks v
atari4x4
 Posted: Tue Aug 05, 2014 6:00 pm |
 best you look into applying for access to the business directory
pete_79
Vehicle: 91 Tin Top
 Posted: Tue Aug 05, 2014 6:38 pm |
henno wrote: just saying that the price of treadplate is usually more anyway... I always thought that was the case too (and it may well be in the thicker gauge stuff), but just bought half a sheet of 1.6mm alloy plate and apparently the checker was $15 a sheet cheaper. Of course I didn't ask the guy how much dearer the checker plate was until after he'd cut the sheet... Sorry to interrupt with that little factoid, you can continue bashing the kid now.
henno
Vehicle: Which one?
 Posted: Tue Aug 05, 2014 6:44 pm |
Well it is the case... generally. There are always exceptions (i.e. shit treadplate will always be cheaper than "good" sheet/plate) but for when comparing apples with apples, it's usually marginally more expensive.
Sources: In another life worked as the inventory manager for the aluminium division of a huge metals distributor. I.e. I used to buy hundreds of tonnes of the stuff at a time.
pete_79
Vehicle: 91 Tin Top
 Posted: Tue Aug 05, 2014 6:54 pm |
Yeah I always thought that was the case, and I only used to buy pallets at a time for our little workshop. But it was a long time ago and I thought maybe times had changed with the thinner stuff, supply and demand and all that.
henno
Vehicle: Which one?
 Posted: Tue Aug 05, 2014 6:56 pm |
Probably. For a while there all treadplate was imported whereas a lot (if not most) of the thin sheet was still sourced locally so it was touch-and-go on pricing, but with the closure of Alcoa's local rolling mills that will no longer be the case.
got_bar_work
Joined: Sat May 15, 2010 8:30 pm Posts: 2214 Location: Brisbane
 Posted: Sun Aug 10, 2014 9:11 am |
1/2" Uhmw sheet for the win
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Sun Aug 10, 2014 10:45 am |
Bis80 slides better
_________________ mlm
1992suzukivitara
 Posted: Sun Aug 10, 2014 6:14 pm |
I've made them out if 3mm steel
