It is currently Sun Aug 02, 2026 6:30 pm
Vehicle: 99 Grand Vitara
Post Posted: Tue Aug 05, 2014 9:28 am
Anyone know if the gearboxes/transfer is the same length between both and will bolt into a GV?
5sp auto would be nice but I think there'd be wiring that would need to be done?
http://www.strictly4x4.com.au
Post Posted: Tue Aug 05, 2014 10:00 am
EVERY XL-7 swap is going to require wiring - the PCM (powertrain control module) needed for the engine & transmission also controls the transfer case and will also be looking for the BCM - so expect to have some challenges.
Post Posted: Tue Aug 05, 2014 10:13 am
Ok, well I'll be dropping a h27a in at the same time, does that change anything if i put the xl7 ecu in as well?
Post Posted: Tue Aug 05, 2014 6:18 pm
Buy a complete XL7 and do a motor, auto and wiring harness swap.
Body loom should be ok ...... maybe
Post Posted: Tue Aug 05, 2014 7:00 pm
Then send auto, wiring harness and ecu for the 2.5 up here.
Vehicle: 2002 Suzuki XL7
Post Posted: Tue Aug 05, 2014 11:32 pm
Does your car have ABS?
The XL-7 has a few more things such as G sensor and all the control modules talk together including the immobilizer which share a specific code (without it engine wont start)
Not sure what effect not having ABS will have, something hopefully the service manual will shine some light on .
But from what i get out of the SDT is that the ECU/AT talk to each other and ABS is separate only thing that is similar is the Brake switch. Plus XL-7 and later Grand vitaras have a torque converter lock that is activated in low range.
Post Posted: Wed Aug 06, 2014 4:33 pm
Cant fit gears in a 5 speed auto
Post Posted: Wed Aug 06, 2014 6:36 pm
Nup no ABS. Anyone got a link to the service manual of the xl7?
That's awesome it has a torque converter lockup in low.
Sweet, was having a look at 5 spd but thought it would be too much work.
Users browsing this forum: No registered users and 330 guests
