It is currently Tue Aug 04, 2026 5:24 am
Vehicle: 1995 Suzuki Sierra SJ70
Post Posted: Thu Aug 07, 2014 9:28 pm
Hi,
I'm buying a Baleno with intentions of removing the G16B engine and mating it to my manual transmission Sierra.
I want to know if an automatic donor Baleno will work, or do I have to get a manual for some reason?
I want to use the ECU, harness and engine,etc from the donor. Is there any reason an automatic donor will not work?
Any experiences with this procedure??
Vehicle: zook
Post Posted: Thu Aug 07, 2014 9:58 pm
The engine will work with your manual box with the adapter.
The ECU may be a different story if it also controls some of the auto box functions in the Baleno, I dont know. Someone else may have that answer.
Post Posted: Fri Aug 08, 2014 7:39 am
Yeah, thats what I was concerned about. Does anyone know if the conversion can be done using automatic ECU and modified harness, or do I need to be chasing a manual transmission donor?
Post Posted: Fri Aug 08, 2014 8:08 am
I think it will be Ok, but I can't be certain. Not sure if the auto baleno runs a different ecu that also controls the trans or not.
Post Posted: Fri Aug 08, 2014 1:10 pm
it works fine, ive also been told that the auto balenos had a different cam which was slightly torquier
Post Posted: Fri Aug 08, 2014 4:45 pm
So you did this conversion Tanshi? Or know someone who has?
Vehicle: MG410
Post Posted: Fri Aug 08, 2014 7:04 pm
Would you need a spigot bearing to support the input shaft?
Post Posted: Fri Aug 08, 2014 7:28 pm
Yes. Flex plate and small spacer will need to be removed and spigot bearing and flywheel fitted
Users browsing this forum: No registered users and 261 guests
