It is currently Sun Oct 25, 2026 11:27 pm
Board index » ausZOOkers » Website Help & FAQs
Post new topic Reply to topic  [ 262 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9  Next
Post Posted: Thu Aug 01, 2013 10:45 am
Is there a guide any where for fitting transfer gears to a vvt jimny push button transfer?
Post Posted: Thu Aug 01, 2013 11:02 am
not sure, maybe suss out bigjimny?
Post Posted: Thu Aug 01, 2013 11:31 am
Haha their search is harder to drive then AZ's
Post Posted: Thu Aug 01, 2013 8:43 pm
Can a vit 1.6 efi auto transfer case be bolted to a vit 1.6 efi 5 speed box?
Post Posted: Thu Aug 01, 2013 9:23 pm
Yes
Post Posted: Sun Aug 11, 2013 10:03 pm
hi all,
i remember someone adding bracing to the front edge of an arb bar recovery point, as in welding plates to both sides of the bar to "increase the surface area". I remember them talking about welding upside down and being there first attempt at welding, but searching with those key words brings nothing.
pretty sure it was in a build thread, and the vitara (se416) was white!
thank you search gods!
Post Posted: Sun Aug 11, 2013 10:19 pm
Chop did it on Burnt Wood's ARB Bar, but I remember someone else doing it too.
viewtopic.php?f=4&t=11387&hilit=burnt+wood&start=420
Post Posted: Sun Aug 11, 2013 10:33 pm
cheers, yeah not the one i was thinking of but thanks anyway.
Post Posted: Sun Aug 11, 2013 10:38 pm
i've been searching, but can't find the other one... i know the one you're talking about.
Post Posted: Sun Aug 11, 2013 10:45 pm
viewtopic.php?f=5&t=18209&hilit=ARB+recovery+point+weld&start=30
Post Posted: Sun Aug 11, 2013 10:58 pm
your a legend Gus, not sure how you managed to find it with those keywords (ARB, recovery point, weld) did you do anything between them or just a space?
THANK YOU!!!!
Post Posted: Sun Aug 11, 2013 11:10 pm
a master never reveals his secrets, but i'm pretty sure Grimbo added a user name to the search to narrow down the results
aka mircowire
Vehicle: JB627
Post Posted: Thu Oct 31, 2013 5:01 am
err, not sure if it's the right place.....
how do i automatically subscribe to a thread as soon as i post in one.....
or must I subscribe manually?
Vehicle: 75 Cruiser
Post Posted: Thu Oct 31, 2013 6:13 am
I'm not sure if this is right, but you can try: http://www.auszookers.com/forum/ucp.php?i=prefs&mode=post
or see "User Control Panel / Board Preferences"
Vehicle: JB627
Post Posted: Thu Oct 31, 2013 6:31 am
Thanks for the speedy reply.
Everything is on, will see how it goes....
Vehicle: Vit swb 95
Post Posted: Thu Dec 12, 2013 1:13 pm
Where is the "Other rides/Car's" thread
looked up to 15 pages in the chat thread, and no luck on the search either :/
Vehicle: Drover pickup turk
Post Posted: Thu Dec 12, 2013 1:36 pm
Previous rides thread?
auszookers.com/forum/viewtopic.php?f=1&t=4857&hilit=other+rides
Post Posted: Sun Aug 31, 2014 12:21 pm
Anyone know categorically what size the hard brake lines on an SV620 Vitara are?
Are the sizes an internal (bore) or external measurement? Calipers say 4.9mm external, so guessing 5mm? It's just off enough for me to worry that it might be 3/16" (4.75mm) internal, though I'm hoping Suzukisan didn't go imperial for one componant...
Anyone clarify?
Post Posted: Sun Oct 19, 2014 4:27 pm
How often do the timing chains need doing on an H20A?
...and do we have a write-up for changing a clutch anywhere?
Vehicle: Vitara/LWB "ZOOKINI"
Post Posted: Tue Oct 21, 2014 8:29 am
How to program a new remote for an aftermarket alarm system...
I don't know the brand that is installed. The keyless fob / "doop doop" thing is busted. It has a fake walnut finish that has warn off, somewhat ruining the illusion of class that I work so hard to maintain.
so is there a thread on reprogramming or programming a new key?
Post Posted: Tue Oct 21, 2014 2:33 pm
Would think it would say in the manual, but usually 150 thou.
Dont think there is a clutch one.... Your turn:)
Post Posted: Tue Oct 21, 2014 5:21 pm
Crap... :lol:
Mine doesn't actually need it yet, but was tempted by another one that looked mint but apparently needed clutch and had 118,000 on it. Seller not replying to SMS, voicemail or e-mail. :(
Post Posted: Tue Oct 21, 2014 5:40 pm
Darkhorse; Ninja has a good write up for the H series timing chains in his GV/XL-7 thread, it's pretty early on in the build stages... was a couple pdf's attached to a post from memory, has nice pretty colour pics n shit.
Jason; any idea on what kind of alarm... i can probably tell you how to reprogram a new remote into it, but probably not best to post a DIY guide on how to steal peoples cars.
Post Posted: Tue Oct 21, 2014 9:23 pm
PM'd Thanks Gus.
Post Posted: Wed Mar 25, 2015 10:35 am
Anything about fitting Factory roof rails to a non roof railed Jimny?
Vehicle: 91 Tin Top
Post Posted: Wed Mar 25, 2015 11:08 am
The guide that Scales did looks pretty good; http://auszookers.com/forum/viewtopic.php?f=17&t=35389
Post Posted: Fri Mar 27, 2015 1:08 pm
Skippy did it to his. Nutserts were used to attach the factory rails but he has since made a custom basket that includes the feet.
Post Posted: Sun Mar 29, 2015 5:59 pm
Hows about power steer onto a non power steer one?
Vehicle: 93 LWB Vitara
Post Posted: Sun May 31, 2015 2:46 pm
The secret to wiring carling switches for suzukis? Not sure about getting the lights to work properly, surely there's a thread on this??
Vehicle: Which one?
Post Posted: Tue Jun 02, 2015 9:31 am
Lights are negatively switched. That's the most common mistake people make when wiring up lights.
